Subahamas Posted February 24, 2020 Share Posted February 24, 2020 Hello my fellow enthusiasts, my 2008 B4 is throwing an engine code p1718. I also have a no start issue. please help. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 24, 2020 Share Posted February 24, 2020 ? I don't see it. I'll try google. https://legacygt.com/forums/showthread.php/trouble-codes-cels-26113.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted February 24, 2020 Share Posted February 24, 2020 https://www.bing.com/search?q=P1718+CEL&src=IE-SearchBox&FORM=IENAE1 Will that help ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted February 24, 2020 Share Posted February 24, 2020 https://www.subaruforester.org/threads/cel-p0700-and-p1718-solved.607049/#post-6096705 That one may have the fixed, as it say's SOLVED. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
