markc0220k Posted February 23, 2020 Share Posted February 23, 2020 Is this 06 spec B axle also fit on 09 spec B? are left and right side the same? they are so hard to find for specfically 09 Spec B. i need both driver/pgr sides. pretty much will need to order and fix them soon. beside, any tips of installation would help please! thanks, mark Link to comment Share on other sites More sharing options...
Chocoholic005 Posted February 24, 2020 Share Posted February 24, 2020 Fronts will fit, rears will not. The 06 has an R160 rear differential and the 07-09 has the R180. Are yours not rebuild-able? Link to comment Share on other sites More sharing options...
markc0220k Posted February 25, 2020 Author Share Posted February 25, 2020 thanks for remind me Choco! Spent a whole morning to learn how to rebuild the cv boots.. yes, the job is little dirty, but the stock shaft itself is much reliable/trouble free! So where can i find those rebuild kit? i searched and found there are two diffrerent lenght but same diameter?! thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted February 26, 2020 Share Posted February 26, 2020 Any auto parts store or the dealer will have them. Or ask Google. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
markc0220k Posted February 27, 2020 Author Share Posted February 27, 2020 ok. ..but same quality/durability? Link to comment Share on other sites More sharing options...
Max Capacity Posted February 27, 2020 Share Posted February 27, 2020 I would think the boots would have to be close, I doubt many repair shops buy OEM parts. But even how much more money is the OEM boot... I would think not much. I did buy a OEM rebuild kit for my right front a few years back and had a repair shop do the work. Or, in JmP's sticky there are a couple post about after market axles. Take a look and cost. BTW, I'm glad a went with OEM kit. Piece of mind is priceless. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Shawn06SpecB Posted February 28, 2020 Share Posted February 28, 2020 28397AG000 is the subaru PN for the inner rebuild kit. Link to comment Share on other sites More sharing options...
markc0220k Posted February 28, 2020 Author Share Posted February 28, 2020 I doubt many repair shops buy OEM parts. But even how much more money is the OEM boot... I would think not much. I did buy a OEM rebuild kit for my right front a few years back .... yea, that's what i'm planning too. Link to comment Share on other sites More sharing options...
markc0220k Posted February 28, 2020 Author Share Posted February 28, 2020 (edited) 28397AG000 is the subaru PN for the inner rebuild kit. thanks Shawn, that's exactly what i'm searching these few days. some of ptj boot for 6MT are only 07, 08 and 09, , Genuine Subaru also has similar info for the parts (its for for 07-09), and your pn is for 06? thats why i'm little confused. coz pretty much at the time i find out the boot is not for mine, the package is already opened and wont be able to return. thanks again Edited February 28, 2020 by markc0220k Link to comment Share on other sites More sharing options...
markc0220k Posted February 28, 2020 Author Share Posted February 28, 2020 Are yours not rebuild-able? no, well..beside, my skill, they should be rebuildable.. still searching/learning tricks to get it done. (will see if i could take some pics.. the boot has little openwound other than that ..they work fine sicne 2~3yrs ago i found it started leaking grease ) Link to comment Share on other sites More sharing options...
