CHRISPY Posted November 21, 2005 Share Posted November 21, 2005 Hi guys, I am installing a boost gauge in the center cubby. gauge is mounted, wiring all hooked up (hooked up to clock wiring. light turns on when the headlights are on. My MILLION dollar question... How the hell did you run the vac line from the engine compartment to the center cubby???!!! Any help appreciated! Cheers, Chris Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted November 21, 2005 Share Posted November 21, 2005 http://legacygt.com/forums/showthread.php?t=3147&highlight=boost is what I did. Link to comment Share on other sites More sharing options...
NewScooby Posted November 21, 2005 Share Posted November 21, 2005 There are 4 popits that you can remove from the drivers side inner fender and pull the liner down. I removed the battery and ran the boost line from the T by the wastegate. under the fuse panel and into the hole in the fender beside the fuse panel. After you remove the fender liner you will see a large oval gromet where the, I believe it is the hood mechanism goes through. use a punch, nail set, or something to make a hole right above the hood release. I used neon orange weedeater string as a fish line to route where I wanted the boost gauge to go. after I had it routed. I taped the boost line to the weedeater sting and pulled it through slow and steady, while lying upside down in the drivers seat! You will need more than 6 feet of boost line to travel this path. I took me exactly 6 ft to get to the steering column. I hope any of this helps! Link to comment Share on other sites More sharing options...
eldiablo Posted November 21, 2005 Share Posted November 21, 2005 There are 4 popits that you can remove from the drivers side inner fender and pull the liner down. I removed the battery and ran the boost line from the T by the wastegate. under the fuse panel and into the hole in the fender beside the fuse panel. After you remove the fender liner you will see a large oval gromet where the, I believe it is the hood mechanism goes through. use a punch, nail set, or something to make a hole right above the hood release. I used neon orange weedeater string as a fish line to route where I wanted the boost gauge to go. after I had it routed. I taped the boost line to the weedeater sting and pulled it through slow and steady, while lying upside down in the drivers seat! You will need more than 6 feet of boost line to travel this path. I took me exactly 6 ft to get to the steering column. I hope any of this helps! That's what I did too... http://www.legacygt.com/forums/showthread.php?p=324308#post324308 My VB Garage... Pumping the air back into despair Link to comment Share on other sites More sharing options...
mccorry Posted November 21, 2005 Share Posted November 21, 2005 Moi aussi..... Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted November 21, 2005 Share Posted November 21, 2005 Moi aussi..... Link to comment Share on other sites More sharing options...
mccorry Posted November 21, 2005 Share Posted November 21, 2005 Me too..... Link to comment Share on other sites More sharing options...
CHRISPY Posted November 21, 2005 Author Share Posted November 21, 2005 Thanks guys for the responses and the links. I was ready to pull my hair out LOL! I ended up running it through the fender, into the A-Pillar, Across the top of the speedo cluster and to the center cubby. If I had to do this all over again I could install one in 30 minutes LOL! I still need to buy a T and connect it to the vac line in the engine compartment but so far so good and it doesn't look like I have any crimps in the line. I'll post pics tonight or tomorrow. Cheers, Chris Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted November 21, 2005 Share Posted November 21, 2005 Me too..... Oh, I thought you meant you were Aussie. Link to comment Share on other sites More sharing options...
derffred Posted November 4, 2006 Share Posted November 4, 2006 Thanks guys for the responses and the links. I was ready to pull my hair out LOL! I ended up running it through the fender, into the A-Pillar, Across the top of the speedo cluster and to the center cubby. If I had to do this all over again I could install one in 30 minutes LOL! I still need to buy a T and connect it to the vac line in the engine compartment but so far so good and it doesn't look like I have any crimps in the line. I'll post pics tonight or tomorrow. Cheers, Chris good, then you can do mine for me i have my gauge mounted in my cubby, but i still have to go out and buy vac lines and a Tee, and hook up the wiring Link to comment Share on other sites More sharing options...
2006Specb122 Posted December 15, 2006 Share Posted December 15, 2006 Hey where are the pics....and where do I put the guage if I have a nav system in my cubby? Link to comment Share on other sites More sharing options...
Legacy05 Posted December 15, 2006 Share Posted December 15, 2006 You can get an AVO gauge pod which sits on the drivers side against the A-pillar ... like how I have mine ... Link to comment Share on other sites More sharing options...
VXCL Posted December 18, 2006 Share Posted December 18, 2006 the auto guys get such a huge grommet to run whatever the hell they want into the car. suck for us...wait for it...wait for it...we have a manual!!! oHHH noooEEESS!!! MT FTW!! MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
2006Specb122 Posted December 18, 2006 Share Posted December 18, 2006 You can get an AVO gauge pod which sits on the drivers side against the A-pillar ... like how I have mine ... Do you have a pic in your garage? Can you post a pic on this forum? I WANT BOOST GAUGE Link to comment Share on other sites More sharing options...
Legacy05 Posted December 18, 2006 Share Posted December 18, 2006 http://legacygt.com/forums/vbpgimage.php?do=full&p=2452&d=1166427504 Link to comment Share on other sites More sharing options...
2006Specb122 Posted December 18, 2006 Share Posted December 18, 2006 thanks for the pic.... I can't decide whether I want that spot or on the steering column Link to comment Share on other sites More sharing options...
