Z3r0_C00l Posted February 13, 2020 Share Posted February 13, 2020 I just wanted to ask of this would be a viable swap, or would it be more hassle than it is worth, as I didn't seem to be able to find any posts regarding it. Link to comment Share on other sites More sharing options...
seanyb505 Posted February 13, 2020 Share Posted February 13, 2020 There's some extra emissions stuff on the 2010. You can get block off plates and delete it. Also the passenger side hard oil line routing is a little different, but it's fine if you use the 2010 lines. I think everything else is the same. You might need to swap a sensor here or there, but if you have everything from the legacy you shouldn't have issues. A few years ago I put 2012 wrx heads on a brand new shortblock from Subaru. With the noted plates and oil lines, everything dropped right in. Link to comment Share on other sites More sharing options...
Berge56 Posted February 18, 2020 Share Posted February 18, 2020 What they said! ^ Link to comment Share on other sites More sharing options...
