Seaking2000 Posted January 19, 2020 Share Posted January 19, 2020 Hi all, my 2006 Subaru Legacy Limited w/Automatic Transmission has been leaking rear diff fluid and has a whining noise while coasting, and a grinding noise while going highway speeds. Now I'm getting some vibration and shudders in stop and go traffic... I'm worried that I might have to replace my rear diff at some point, but I'm having trouble determining exactly what ratio will fit my Legacy Limited. I found this part number (38312AA022) on the Subaru parts website and it's been discontinued, but I couldn't figure out the size or ratio, or if other rear diffs would fit my car. Any help on this subject would be very much appreciated. Thanks! Link to comment Share on other sites More sharing options...
Max Capacity Posted January 21, 2020 Share Posted January 21, 2020 Welcome to the Forum, read the stickys up top, there is a list of ratio's in the cars. You may want to check out http://www.car-part.com get a junkyard unit. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Seaking2000 Posted January 21, 2020 Author Share Posted January 21, 2020 Welcome to the Forum, read the stickys up top, there is a list of ratio's in the cars. You may want to check out http://www.car-part.com get a junkyard unit. Thanks for the reply! I checked out the stickys, and I'm having trouble finding the ratio for my exact model. A Subaru Legacy 2006 Limited 2.5 4AT. Any help would be greatly appreciated! Link to comment Share on other sites More sharing options...
Max Capacity Posted January 22, 2020 Share Posted January 22, 2020 http://people.csail.mit.edu/ilh/vacation/ The service manual may help. Try over on NASIOC at the top of there tranny forum, they may have more info. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Nonamedude Posted January 22, 2020 Share Posted January 22, 2020 From what I've gathered from discussion on the outback forums, for non turbos, some have limited slip and some don't. Gear ratios should be the same between and in the FSM. But best bet is to probably check the rear diff page and the gearing page in the FSM and then you'll need to crawl under the car for the markings on the differential to be sure of what you have. That said they all for the most part fit. You just might have some slightly different performance and whatnot. Link to comment Share on other sites More sharing options...
