Falcor Posted January 3, 2020 Share Posted January 3, 2020 What is the difference in the following 2 gear oils? Motul Motylgear 75W90 Motul Gear 300 75W90 The only difference I see is the Gear 300 is fully synthetic and cost about $10 more a bottle. Motylgear is semi-synthetic. Is there that much of a noticeable difference? Link to comment Share on other sites More sharing options...
Falcor Posted January 3, 2020 Author Share Posted January 3, 2020 I ended up going with the Gear 300. Didn't want to keep waiting since I saw a good deal on Ebay for $75 for 4qts. I have a feeling that's what most here would go with. Link to comment Share on other sites More sharing options...
creep_nu Posted January 3, 2020 Share Posted January 3, 2020 quick research shows motylgear is semi-synthetic while the gear300 is full synthetic. looks like the additive package in the motylgear might be a little better for older gearboxes, more stuff to help the syncros out, but otherwise not a whole load of difference aside from the semi-vs-full-synthetic thing. if you got a good deal on the 300 then you got a good deal Link to comment Share on other sites More sharing options...
SchwarzeEwigkt Posted January 3, 2020 Share Posted January 3, 2020 I asked the same question when I changed the oil in the gearbox in my old Audi. I ended up going with Gear 300 myself and was very happy with it. Turned a gearbox that wouldn’t shift into second in the cold into one that worked kind of okay in the cold. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
