jdog593 Posted November 16, 2019 Share Posted November 16, 2019 Hi, I recently put h11 LEDs 6k into my headlights on my 2015 Subaru Legacy Premium and the second week with them in I noticed one side keeps flickering. It will turn off then come back on, I noticed it the most when I’m turning or on bumpy roads. Everything is plugged in all the way, I made sure. I also noticed some slow cranking when trying to start up or once the car took two cranks to start I don’t know if that has anything connected. Thanks for the help. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
15legacy1657616192 Posted November 18, 2019 Share Posted November 18, 2019 Hi, I recently put h11 LEDs 6k into my headlights on my 2015 Subaru Legacy Premium and the second week with them in I noticed one side keeps flickering. It will turn off then come back on, I noticed it the most when I’m turning or on bumpy roads. Everything is plugged in all the way, I made sure. I also noticed some slow cranking when trying to start up or once the car took two cranks to start I don’t know if that has anything connected. Thanks for the help. Sent from my iPhone using Tapatalk What brand are you running? Also, are you experiencing flickering of the daytime running lights, or are you referring to the low beams? Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted November 18, 2019 Share Posted November 18, 2019 LED are typically rated to run 6-24V. flickering LED = defective and time to replace. Link to comment Share on other sites More sharing options...
testa422 Posted November 22, 2019 Share Posted November 22, 2019 sounds like shitty cheap LEDs Link to comment Share on other sites More sharing options...
One1657616242 Posted November 28, 2019 Share Posted November 28, 2019 I'm going to suggest check your ground connection on the battery Link to comment Share on other sites More sharing options...
