Jolbaru_LGT Posted September 14, 2019 Share Posted September 14, 2019 (edited) So, I'm hooking up a double DIN radio, and I've got everything connected where it should be, except for the i-88 harness. I did get the approved JDM setup and D.Carter wiring harnesses. But on the I-88 climate control adapter, I noticed that it has a red power wire. I don't really want to splice into the harness wire that's going to my aftermarket Alpine unit. Should I run a wire from the fuse box to that connection? I see eBay offers gadgets like this. Is it a good idea? If so, which fuse slot would I use? Edited September 15, 2019 by Jolbaru_LGT Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted September 15, 2019 Author Share Posted September 15, 2019 (edited) Or can you do a 3 way butt connector like this inline where the aftermarket(Alpine) wiring harness connects the red(12v) power wire and split off the power to the climate control via the I-88 connector? I may be in the wrong area, this might be more of an aftermarket audio forum question.. Edited September 15, 2019 by Jolbaru_LGT Link to comment Share on other sites More sharing options...
Kazsmir Posted September 16, 2019 Share Posted September 16, 2019 I just wired mine in with the factory harness and 14 pin adapter from SVXDC; red, to red, to red, and done. Link to comment Share on other sites More sharing options...
Ninjacheezit Posted September 16, 2019 Share Posted September 16, 2019 I just wired mine in with the factory harness and 14 pin adapter from SVXDC; red, to red, to red, and done. Same my climate control and headunits red wire connects to the same red wire on my adapter. Simple and done. No need to make it harder. Link to comment Share on other sites More sharing options...
GearJamr Posted September 18, 2019 Share Posted September 18, 2019 I soldered my power wires together. No need to splice into anything. Link to comment Share on other sites More sharing options...
