discojon Posted August 25, 2019 Share Posted August 25, 2019 (edited) PRICE DROPPED TO $2750! MUST GO!. Bought a Tesla Year, Make and Model: 2006 Legacy GT Wagon Color: BSM Miles: 255ish Transmission: 5EAT with Hexmods Title: Clear Lien: no Location: Scott Depot, WV VIN: 4S3BP676364303258 Seller's email address: jeffries.cody@gmail . com Asking Price: $3,000 Need to sell my 2006 LGT Wagon. I've moved on from it and I need money to pay bills. It has new tires, and I believe the below mod list is accurate. The bad news is the drivers side head gasket needs replaced. Compression on that side was around 95, compression on the passenger was 125 in both cylinders. I'm not going to part it out as i need the car gone ASAP. It runs and drives, never overheated. A simple head gasket job would get the car running great again. I just don't have the time or cash to do it right now. The body is great, only a couple dings. Interior is also great. Has Subaru rubber mats with it and cargo mat. Heated seats, and massive sunroof. Bit of surface rust on bottom side of drivers door at seam. Motor / Drivetrain: CP forged pistons Stock connecting rods and other internals Stock rebuilt heads GrimmSpeed crosspipe, gasked matched ported oem manifolds GrimmSpeed Uppipe Ceramic Coated. Invidia catless downpipe Stock CBE SPT turbo heat shield BNR 18g turbo DW 740 Injectors DW 65wc Fuel Pump GrimmSpeed EBCS Turkeylords EBSC fittings Fast Motorsports Black coated FMIC and piping Forge BOV 100% recirc PLX SM-AFR v3 with custom Romraider build to log Open Source Tune by Cyro STI dogbone mount Group n motor mounts Hex Mod Valvebody Upgrade Suspension: Front: Koni inserts H&R Springs Whiteline front LCA bushings Whiteline front LCA anti lift kit (rear bushings) Whiteline ball joints Whiteline tie rod ends Whiteline Front 22mm adjustable sway bar and bushings Whiteline power steering rack bushings Rear: Whiteline KTA124 Whiteline W63394 Whiteline 20mm adjustable sway bar and bushings Koni struts H&R Springs Spec B Alum. Trailing Arms Spec B Alum. Lateral Links AVO Sway bar reinforcements Interior: JDM double din hvac console Pioneer AVIC navi / headunit Installed: VBG-1 SM-AFR v3 Edited April 2, 2020 by discojon Link to comment Share on other sites More sharing options...
gkinslow Posted August 28, 2019 Share Posted August 28, 2019 Properly formatted FS post. Thanks. GLWYS bump. Link to comment Share on other sites More sharing options...
discojon Posted March 2, 2020 Author Share Posted March 2, 2020 Ok guys, I really need this thing gone. $4000 takes it. Link to comment Share on other sites More sharing options...
discojon Posted March 8, 2020 Author Share Posted March 8, 2020 Price Dropped to $3,000. I bought a Tesla and need it gone Link to comment Share on other sites More sharing options...
RedStage Posted March 11, 2020 Share Posted March 11, 2020 that is a damn good looking Leggy. when was the head work done? Link to comment Share on other sites More sharing options...
discojon Posted April 2, 2020 Author Share Posted April 2, 2020 Motor work and drivetrain work was done about 100k ago. I really need the car gone. Price reduced to $2750. Link to comment Share on other sites More sharing options...
cal71919 Posted April 16, 2020 Share Posted April 16, 2020 Sent you an email. Link to comment Share on other sites More sharing options...
