Car wont run! Security lockout???
Went to start my OBXT this morning and would crank and turn over for a few seconds then turn itself off. No codes, traction control, CEL, battery, and oil lights would come on, then if I tried to start it, it would just crank with no ignition. I noticed that my security light kept blinking even when I unlocked the car and was sitting in it. Not sure what is happening, but need to get this fixed ASAP. Any ideas???
If you have a secondary key - try with that.
Also try with disconnecting the battery - and make sure the battery is good.
Otherwise it can be the antenna that's in a ring around the ignition lock or the wiring to the BIU. At worst it's the BIU.
Some reading on the matter of immobilizer:
https://subaru.locksmithsdrm.com/SubaruSDRM/downloads/subaru_service_bulletin.pdf
A thread on the antenna.
https://legacygt.com/forums/showthread.php/05-legacy-immobilizer-antenna-location-help-225253.html
Unfortunately the immobilizer is one of the items that when it starts to act up requires some good tools that only a friendly workshop or possibly locksmith might have.
Also look here, search for "immobilizer" in this doc: https://www.bedug.com/pics/Subaru/2009/2009.pdf
