downero Posted November 16, 2005 Share Posted November 16, 2005 Sirs Mine is a Legacy GT 1996 Twin-Turbo. Sometimes the "Check Engine" light will light up. After a while it will disappear. But sometimes it will light up for a long time. 50,000kms reading on the odometer. What could be the problem? There is no subaru dealer here in the philippines right now. thanks. Link to comment Share on other sites More sharing options...
Aczwild Posted November 16, 2005 Share Posted November 16, 2005 02 sensor??? Does it feel like the car is sluggish under power, like you get off of the gas and a parachute deploys out the rear? JDM'd All to hell Thanks Jimmy @ Hkc-Speed.com! RIP Coxx & Thanks Link to comment Share on other sites More sharing options...
agctr Posted November 16, 2005 Share Posted November 16, 2005 I know that one of our long standing members Sube555 aka Seth used to have this type of vehicle, he may know something. I will forward this to him now. Ada///M. Link to comment Share on other sites More sharing options...
SUBE555 Posted November 16, 2005 Share Posted November 16, 2005 Well I never had a twin-turbo model, I had one of such year. Is it stock, could you better explain a little what it does when it has these cels or doesn't act much differently? Just trying to help. Link to comment Share on other sites More sharing options...
JBLU24 Posted November 16, 2005 Share Posted November 16, 2005 invest in a code reader .......or try to run to your local Autozone or equivalent while the CEL is on and they'll read it for you for free........tell us the code it would help...... scrath that i just saw youre in the phillipenes- try finding a code reader- maybe Ebay????? Link to comment Share on other sites More sharing options...
forestir Posted November 16, 2005 Share Posted November 16, 2005 Mine is a Legacy GT 1996 Twin-Turbo. Sometimes the "Check Engine" light will light up. After a while it will disappear. But sometimes it will light up for a long time. From what I understand, CEL will flash on briefly (a few seconds) if engine detects pinging. If it stays on for a few trips (perhaps days), it could be an intermittent problem like a loose gas cap. Have you had a bad batch of fuel? Low octane or watered down? A bad sensor could also cause an intermittent problem. Maybe O2 going bad. As previous advice, you'll need someone with OBDII reader to check the codes. Most shops will be able to do this, but they may not know Subaru-specific codes--they can still read it and you can then post here for the meaning of the code. Link to comment Share on other sites More sharing options...
downero Posted November 16, 2005 Author Share Posted November 16, 2005 Thanks guys! Mabuhay! Link to comment Share on other sites More sharing options...
mwiener2 Posted November 28, 2005 Share Posted November 28, 2005 moved to older legacy My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
