fizzlefish Posted June 24, 2019 Posted June 24, 2019 I was originally going to lower the LGT but after attending boxerfest and seeing some nice lifted Subi's im going up. I know the Outback suspension is crap. Looking for other options for lifts. Are parts from the outback interchangeable? Thanks guys.
fizzlefish Posted June 24, 2019 Author Posted June 24, 2019 I also found these lifts. Might do a 2inch and well my wheels and get something to put some general grabbers on. https://andersondesign-fab.com/product-category/suspension/legacy/2005-2009-subaru-legacy/
Outblack Posted June 25, 2019 Posted June 25, 2019 Blasphemy! Leave that nonsense to the outbacks! Legacy’s go lower not higher.
flevum16 Posted July 7, 2019 Posted July 7, 2019 I had a lifted 05 LGT Wagon. It had direct swapped outback suspension. I believe there is a NASOIC thread somewhere with all the suspension compatibility across all models available. I wish i could tell you more but i bought it with the lift. The car was my favorite I ever owned... I loved the lift!
Diomedes88 Posted July 7, 2019 Posted July 7, 2019 I lifted my 04 lgt, 2inches. Moved to Kodiak Alaska I was hitting everything lol after the lift I was fine. Ordered stock 04 outback springs and coils, bolted right up no problems. I was reading after 3in it starts to mess with your suspension. The front ended up a little higher than I want then came down a little after everything settled. Sent from my iPad using Tapatalk
utc_pyro Posted July 7, 2019 Posted July 7, 2019 .... know the Outback suspension is crap. ... It's not crap, it's what you SHOULD do first if you want to lift the thing. Using other lift kits you'll just loose suspension travel, and cause bottoming out issues on your rear shocks. Use OEM outback or Kind springs, and new outback KYB struts. If that's not enough, THEN start looking at spacing it up.
