13LegacyBurchard Posted June 14, 2019 Share Posted June 14, 2019 Anyone know the torque specs in lb/ft for the Brake Caliper Bolts and the Wheel Lug Nuts? Link to comment Share on other sites More sharing options...
Sarang Posted June 15, 2019 Share Posted June 15, 2019 lug nuts are 95 ft-lbs Link to comment Share on other sites More sharing options...
dgoodhue Posted June 15, 2019 Share Posted June 15, 2019 I just replaced my rotors recently. The caliper bolts are ~20ft-lbs (The factory torque spec are converted from N m). Not that it makes that much of difference but the lugs nuts are ~89ft-lbs. Link to comment Share on other sites More sharing options...
amusa Posted June 17, 2019 Share Posted June 17, 2019 The lugs nuts are ~89ft-lbs. Correct, wheel nut torque is listed in Specifications 12-9 in the owner manual. Link to comment Share on other sites More sharing options...
