Ares3985 Posted June 10, 2019 Posted June 10, 2019 Not sure if I’m even having an issue but I noticed that my peak boost is only hitting 12.5 with a stage 1 tune. Target boost is 14.5. AF learning is at 6.5%. I have attempted a boost leak test a few times with no results. Can’t pressurize. I just get air coming out my oil fill. I know I need to pinch off a few lines but I really don’t know which. The diagram on boostleaktesters is for an sti not a legacy so it’s slightly different. Anyway. I can’t get it to work. Is there a simpler way in which I don’t need to pinch anything off? Obv going right to the turbo isn’t an option as it isn’t accessible. And yes yes I know that this has been posted about before. I read all of them and still can’t get it to work. I even tried just capping the intake and going through the small hose on the bov. Not working either. Sent from my iPhone using Tapatalk
Notorious Posted June 10, 2019 Posted June 10, 2019 Have you looked through all AF learning parameters? A-D? I’d upload a data log
Ares3985 Posted June 10, 2019 Author Posted June 10, 2019 Yeah I can get one later. I made one yesterday but wasnt w the default log settings and was 2500-5500. I’ll make a solid one today and upload. Sent from my iPhone using Tapatalk
Andy_Mac Posted June 11, 2019 Posted June 11, 2019 I've never bothered blocking any hoses when checking mine, or opening the oil filler, what's the reasoning for opening that? Reducing the risk of over pressurising the system? 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness
Ares3985 Posted June 12, 2019 Author Posted June 12, 2019 I've never bothered blocking any hoses when checking mine, or opening the oil filler, what's the reasoning for opening that? Reducing the risk of over pressurising the system? Yes supposedly you can mess up the motor. So you were able to build pressure without pinching any lines off? Did you go straight to the turbo with the test or did you go through the inlet pipe? Sent from my iPhone using Tapatalk
Andy_Mac Posted June 12, 2019 Posted June 12, 2019 Yea have heard of people blowing camshaft seals when chucking too much pressure in. My setup uses refrigeration gauges so exact pressure control is extremely easy to control. Doesn't hold pressure super well but, drops down in 5-10sec if bottle is closed. just have the bottle and gauges open holding 10psi, have found all my issues with that little pressure. 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness
Ares3985 Posted June 12, 2019 Author Posted June 12, 2019 Hmm weird that I can’t build pressure. I have a similar gauge that I can also easily control pressure. About how long of having air on does it take for you to build the pressure? I would think it would build relatively quick. I got nervous when I hear all the air going into the motor and turn it off. Sent from my iPhone using Tapatalk
moral hazard Posted June 12, 2019 Posted June 12, 2019 Are you able to test with a smoke machine , that way I guess you wouldn't need pressure.
Ares3985 Posted June 12, 2019 Author Posted June 12, 2019 Are you able to test with a smoke machine , that way I guess you wouldn't need pressure. I made a smoker out of a paint can but it doesn’t flow right. I think I’m gonna get a cheap Halloween fog machine and try that. Should work well Sent from my iPhone using Tapatalk
Andy_Mac Posted June 13, 2019 Posted June 13, 2019 Only takes 10-30sec to get enough volume in there to hear any leaks. A smoke machine still pushes some pressure. Some leaks won’t show up well without pressure. Especially rubber lines that need to be pushed open to leak. 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness
ttnio Posted June 13, 2019 Posted June 13, 2019 ultra violet light w/the smoke machine . no pressure to blow any seals.
Ares3985 Posted June 13, 2019 Author Posted June 13, 2019 Well looks like I did have one leak that I saw. Coming from the turbo inlet. Also noticed that the previous owner has removed the hose clamp for whatever reason. Just going to put a new inlet on In case it’s cracked. All the smoke seemed to be coming out of the bottom of the inlet. Tough to see it coming out but it makes sense if the smoke was in that area. Tried to pressure test again also and couldn’t build pressure. Going to install the inlet and retest. Sent from my iPhone using Tapatalk
