mbazzano88 Posted May 21, 2019 Share Posted May 21, 2019 TL;DR: 05LGT 165k - running poorly, lack of power but reading full boost. Shop replaced O2 sensor, injectors, now doesn't reach full boost, new scary rattling noise. OK. Sorry for the potentially lengthy post but I'm at a loss for what to do about this. <rant> Let me start by saying this shop has done all of my work on the car for the past 6 years and for the last 5 have been awesome and friendly. Began a few months ago, car would stutter and hesitate under acceleration, and really feel underpowered when it smoothed out. I have the Torque Pro app so I can monitor some things including boost (17.5psi, which is correct for the max boost per my stage 2 tune at this shop), and I was reaching that number even though it didn't feel right. So I bring the car to the shop and describe the problem. Shop tests it and says I'm running lean, blames O2 sensor. I OK the work and it is replaced. I pick the car up, and it is great again, everything is reaching the correct numbers, the car feels responsive and pulls hard just like it used to. I'm happy. UNTIL that same day, it begins hesitating again and again feels underpowered. I check the boost numbers, it is still hitting the target of 17.5psi, but stuttering and feeling slow again. I call shop back and say hey, that problem came back. Shop says O2 sensor could have been masking another problem, explains that injectors would be the next thing to replace to fix this issue (to their credit they mentioned injectors when I picked the car up from the O2 sensor replacement). I'm hesitant to do it since I'm trying to sell the car and don't want to put more money into it than I could sell it for, but I OK the work again after getting reassured that this is the most likely cause of the problem and the shop owner would try this if it were his own car. Work is done, I pick it up and drive it home. No longer stuttering, but still feels not quite right. I load up Torque and see that I'm now only hitting 13psi instead of the 17.5psi, and there is a light metallic rattling noise when boost starts to build. I am not happy. I call the shop and explain that there is a new problem, ask about what they had to do to the car. Shop says they replaced the injectors. I asked if they had to change anything with the tune. Shop says no. I tell them I'm reading 4psi low and there's a new mechanical noise under acceleration, maybe something went wrong with installation? Shop gets immediately defensive, tells me my car is trying to fall apart at every corner. I ask why nobody told me there was a new noise and the car wasn't hitting full boost. Shop says they do a pressure test but don't take the cars out for a drive after service and floor it, and running lean could cause the turbo to reach higher boost pressures since it is running hotter, so new injectors running correctly makes less boost. (You don't need to floor it to get the noise to happen. You can't drive without the noise happening). Shop offers to inspect the car for free (after much questioning on my end) but says it sounds like my turbo is dying and I am going to end up putting a lot of money into a dying car. A couple of things bother me about this. One is that they didn't test the car before calling me and telling me it is done. Another is that on both occasions the owner called me and asked for payment over the phone while telling me the work was complete. (what business makes you pay for something before you pick it up?) A third is that this latest issue seems very different than what I brought it in for and just HAPPENED to pop up after bringing it back from getting work done. Could somebody help me sift through all of this information? I don't know enough about these cars to make sense of any of it. Will a lean running turbo make higher boost? Wouldn't a dying turbo not hold that boost even if it was running lean? What could have gone wrong with an injector install? I get the feeling that this job was rushed but have nothing to back that up with. </rant> Link to comment Share on other sites More sharing options...
ttnio Posted May 21, 2019 Share Posted May 21, 2019 find another shop that won't suck your money. Link to comment Share on other sites More sharing options...
seanyb505 Posted May 21, 2019 Share Posted May 21, 2019 Does the rattling noise increase with rpm? If all shields looks and feel tight, I would pull the downpipe and check the turbo shaft for play. I've paid the shop before driving off. Never over the phone, but it sounds like they kinda know you if you've been around for 5 years. Link to comment Share on other sites More sharing options...
mbazzano88 Posted May 22, 2019 Author Share Posted May 22, 2019 The rattling noise comes on around 2k rpms and does increase. I'll check for anything loose. Have never pulled the downpipe before, is it relatively straight forward? I felt like they were familiar with me but the last two times its been completely different. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 22, 2019 Share Posted May 22, 2019 If you've never pulled the Dp before it can be a job at first. What town do you live in ? There are a number of heat shields that could be loose at this age. My 05 has almost none of them left on the car. When was the last time your spark plugs were replaced ? are they gaped at .028" ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
08SpecB_DE Posted May 23, 2019 Share Posted May 23, 2019 Do you still have the factory catted up-pipe installed? Link to comment Share on other sites More sharing options...
mbazzano88 Posted May 23, 2019 Author Share Posted May 23, 2019 No, I have a catless up. Found two wires hanging out in the passenger footwell, they have green blocky ends and they aren't connected to each other? Link to comment Share on other sites More sharing options...
rougeben83 Posted May 23, 2019 Share Posted May 23, 2019 that's fine, those are the diagnostic plugs - you connect them if you want to run diagnostics on the ECU (or make changes, like during a flash). Otherwise they remain unconnected and tucked away. Link to comment Share on other sites More sharing options...
WahooNo2 Posted May 24, 2019 Share Posted May 24, 2019 +1 for spark plugs and loose heat shields With torque are you seeing high >10% short and long term fuel trims *that would be indicative of it needing to add more fuel because you are running lean* and may have a leak somewhere. Check the hose to the throttle body to the intercooler clamps and hose itself. The end that goes to the intercooler on mine started to fall apart around 135k and I replaced it with a silicone one. Have you checked the vacuum line that goes from the fuel pressure regulator to the intake manifold to see if it is loose? If not do that. Mine was loose before and was doing weird stuff but i was just on stage 1 at that time. I cut the line about an inch from the end and reattached it and it seemed to help. Check other vacuum lines too like the bypass/blow off valve one and brake booster. Finally have you replaced your in tank fuel filter or pump? It is supposed to be a lifetime filter but at over 150k on the pump and filter and you not being stock it may be having a heart attack with being plugged or struggling. You can also see if it is really a fuel pressure/flow issue if you check with a pressure gauge. Link to comment Share on other sites More sharing options...
JmP6889928 Posted May 24, 2019 Share Posted May 24, 2019 Is it stock DP? Almost sounds like the cat is loose in the can and is bouncing all over the place, hence the rattling. If so, it can clog up the exhaust path and not allow you to push the exhaust thorough. Link to comment Share on other sites More sharing options...
boxkita Posted May 24, 2019 Share Posted May 24, 2019 I'd find another shop, as it appears your shop has converted to the cancer that affects many subaru shops after awhile. Mostly that shoddy work is acceptable. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
