36r Posted May 8, 2019 Share Posted May 8, 2019 So it seems that to install the OEM splash guards drilling needs to happen. On the rear, it seems that the drilling is all plastic, which is fine, but the front, there seems to be sheet metal to drill through. This seems crazy to me, as it is asking for rust to begin. Does anyone know if this is true, or if you only need to drill through plastic as well? Thanks! Link to comment Share on other sites More sharing options...
Grnlantern1 Posted May 8, 2019 Share Posted May 8, 2019 So it seems that to install the OEM splash guards drilling needs to happen. On the rear, it seems that the drilling is all plastic, which is fine, but the front, there seems to be sheet metal to drill through. This seems crazy to me, as it is asking for rust to begin. Does anyone know if this is true, or if you only need to drill through plastic as well? Thanks!I dont think you have to drill anything. I believe you have clip nuts and just pop out the plastic plugs in front and the upper part should already have holes there.. Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
roughriduz Posted May 8, 2019 Share Posted May 8, 2019 Here is a link to the install instructions. Looks like it's drilling into the metal below the door. I went with Rally Armor flaps on mine. Look much better and no drilling required. https://subaruonlineparts.com/docs/J101SAL100.pdf Link to comment Share on other sites More sharing options...
SubieN8 Posted May 8, 2019 Share Posted May 8, 2019 Yep, I had to drill the underside hole only, as the hole didn't exist on my 50th Anniversary edition. I drilled the rear, but not the front. It sits flush and is still very secure, so I am fine with it as is. Link to comment Share on other sites More sharing options...
Painless Posted May 8, 2019 Share Posted May 8, 2019 I had to drill as well (but was not expecting to). Flap has a hole, body needs a hole to match. Wasn't an issue once complete. Link to comment Share on other sites More sharing options...
iyalla Posted May 10, 2019 Share Posted May 10, 2019 I have mine and im waiting for warmer less wet days to install. Im prepared to drill. Its drilling into the bottom of the plastic side skirt and bottom of plastic rear bumper. No worries there. Link to comment Share on other sites More sharing options...
ammcinnis Posted May 4, 2021 Share Posted May 4, 2021 You'll need an impact driver.Huh? "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
Righteous_fire Posted May 6, 2021 Share Posted May 6, 2021 I'm actually about to install these myself. If you haven't gone ahead with it yet, I'll let you know what I find out. Link to comment Share on other sites More sharing options...
Righteous_fire Posted May 15, 2021 Share Posted May 15, 2021 For the fronts, you install the metal clips in the holes on the front, but underneath, you will have to drill a hole in the running board for the plastic clip. In the rear, you will have to drill a hole for the top position of the splash guard at the top position on the edge, and drill a hole underneath for the plastic clip. Link to comment Share on other sites More sharing options...
