outahere Posted April 26, 2019 Share Posted April 26, 2019 Just curious if anyone has tried NGK's new "ruthenium" plugs. http://www.ngksparkplugs.ca/products-spark-plugs-Ruthenium%20HX.cfm There are 2 versions available, one for normally aspirated, and one for turbocharged/supercharged engines. ....PSPE® (projected square platinum electrode) provides the best ignitability and service life for high heat engines. NGK patented design recommended for turbo and supercharged engines.... Patented high ignitability DFE and PSPE tip designs provide the most efficient and complete fuel burn of any aftermarket plug, resulting in quicker throttle response, smoother idle and better cold startup NGK's Ruthenium alloy technology provides superior oxidation resistance, delivering unparalleled durability and outstanding service life Ruthenium HX™ contains all the features that enthusiasts expect from NGK spark plugs, including a high grade alumina silicate ceramic, trivalent plated, cold rolled threads, and the highest quality manufacturing and testing... Link to comment Share on other sites More sharing options...
Notorious Posted April 27, 2019 Share Posted April 27, 2019 Might be a gimmick, who knows. These plugs haven’t been out long enough to give any validity to the argument over Iridium plugs yet. Even then, most of us replace Iridium spark plugs on a mileage interval that is less than what they are rated to last for anyways. Link to comment Share on other sites More sharing options...
ehsnils Posted April 27, 2019 Share Posted April 27, 2019 Wear on electrodes is just one of the factors to consider on spark plugs. There's also contamination of the insulator that could result in surface conduction and loss of spark. this is of course less of a problem with lead-free fuel than it was before. Link to comment Share on other sites More sharing options...
