Brisvegas Posted April 18, 2019 Share Posted April 18, 2019 Link to comment Share on other sites More sharing options...
DrD123 Posted April 19, 2019 Share Posted April 19, 2019 it was only 4 quarts low... is that bad? Link to comment Share on other sites More sharing options...
Grnlantern1 Posted April 19, 2019 Share Posted April 19, 2019 Subies normally start running 1Qt Low about a 1000 miles before your regular oil change mark.. So when you hit the special mark just keep an eye on it.. Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
ehsnils Posted April 19, 2019 Share Posted April 19, 2019 I see that engine manufacturers soon will get a fault code set on low oil level and prevent the engines from being started.  "The Money Lamp" is on. Link to comment Share on other sites More sharing options...
capttris Posted April 19, 2019 Share Posted April 19, 2019 It has always amazed me that with all of the safety and protective & electrical devices and sensors on a car, that there isn't more protection for low oil level. I know the Subaru engines we have now, have a low oil level sensor, but I think that it's not common for other cars to have this. And other than a light coming on, the low oil sensor doesn't de-rate/limp home mode, etc. Believe me, I agree that Idiot lights are for, well, idiots. People shouldn't wait for a light or problem to pop the hood and check things out. Some issues and idiot lights are not preventable and can happen without warning. But running low and OUT of oil. 100% preventable. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted April 19, 2019 Share Posted April 19, 2019 Subies normally start running 1Qt Low about a 1000 miles before your regular oil change mark.. So when you hit the special mark just keep an eye on it.. Sent from my SM-G965U using Tapatalk    I got two of them that do not lose any perceptible amount of oil between oil changes... but then again I do not beat the pee out of the cars either....  2003 is at 140K 2014 us at 60K Link to comment Share on other sites More sharing options...
Norskie Posted April 19, 2019 Share Posted April 19, 2019 Subies normally start running 1Qt Low about a 1000 miles before your regular oil change mark.. So when you hit the special mark just keep an eye on it..  I wouldn't say it's 'normal' or 'typical' that they burn oil, but I also wouldn't say it isn't entirely unexpected. We've had four Subaru's and only one - 2005 OBXT 5MT - burned oil. By 150k it was burning about a quart or two per 5000k (the same as my Prelude at the same mileage). Link to comment Share on other sites More sharing options...
ncted Posted April 19, 2019 Share Posted April 19, 2019 None of my Subarus have ever consumed that much oil. I check regularly, and all have had limited or no oil consumption. Of course, then there is my co-worker with a 2002 WRX with 168,000 miles which was using a ton of oil until he got his rear main seal and valve cover gaskets replaced. Now, it uses virtually no oil. Link to comment Share on other sites More sharing options...
tmoney468 Posted April 19, 2019 Share Posted April 19, 2019 My 2012 Impreza burnt 1.2qts in 1200 miles, got the shortblock replacement and that helped the consumption.  Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Norskie Posted April 21, 2019 Share Posted April 21, 2019 Just to add to this, a few years back I asked a Subaru SA what usually kills the EJ255's (turbo outbacks) and he said "oil starvation". Pressed for details, he couldn't say how the oil starvation occurred ... whether low on oil, or a banjo bolt clog, or a cracked oil pickup. These are known Subaru problems which aren't necessarily indicated with a dash light indicating low oil volume or pressure ...  It is plausible (i.e. I do this too) that an owner spot checks oil level once in a while and grows complacent when, after a few OCI's, there is no oil consumption. Then suddenly it does burn oil and they find themselves on the side of the road, 2000 miles after an oil change, with the oil light on. This happened with out Audi; in the course of 25k it would never burn oil, except for maybe three times it just gulped down a few quarts between an OCI. It was the weirdest thing ever. I will saw that I'm happy that Subaru hasn't done away with the dipstick. My BMW didn't have a dipstick, and other than draining the oil to measure the volume, one had to trust the on-dash display, as reported by (known to be faulty) oil level sensors. Link to comment Share on other sites More sharing options...
BobbyR Posted April 21, 2019 Share Posted April 21, 2019 Our Turbo Outback 2.5XT never burned any oil but the turbo blew all the same, requiring an engine replacement. What a disaster that car was. The new Legacy uses no oil, as expected. Link to comment Share on other sites More sharing options...
musicman Posted April 22, 2019 Share Posted April 22, 2019 2016 3.6r uses little to no oil between changes as the stick level is always good. Link to comment Share on other sites More sharing options...
STI_. Posted April 27, 2019 Share Posted April 27, 2019 Subies normally start running 1Qt Low about a 1000 miles before your regular oil change mark.. So when you hit the special mark just keep an eye on it.. Sent from my SM-G965U using Tapatalk   Normally?? My MY 16 3.6R uses about 1/3 qt. every 5,000 miles.  Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Brisvegas Posted April 29, 2019 Author Share Posted April 29, 2019 2016 3.6r uses little to no oil between changes as the stick level is always good. Ditto here. Link to comment Share on other sites More sharing options...
