MBP Posted April 12, 2019 Share Posted April 12, 2019 Do I really have to lift the F'ng motor to do this??? Sent from my SM-G960U1 using Tapatalk Link to comment Share on other sites More sharing options...
Brighton96 Posted April 12, 2019 Share Posted April 12, 2019 Yep. You can take the pitch stop loose and the two studs loose for the mounts on the cross member and jack up the engine a few inches which should be enough to pull the pan. Link to comment Share on other sites More sharing options...
Thor294 Posted April 12, 2019 Share Posted April 12, 2019 Yep. You can take the pitch stop loose and the two studs loose for the mounts on the cross member and jack up the engine a few inches which should be enough to pull the pan. yup ezpz Link to comment Share on other sites More sharing options...
Leggyobw97 Posted April 12, 2019 Share Posted April 12, 2019 double check the instructions on the gasket material you're using too. mine said to wait 24 hours before filling with oil, almost missed that. Link to comment Share on other sites More sharing options...
