RottenJeeves Posted April 9, 2019 Share Posted April 9, 2019 Hey guys/gals. Trying to figure out where to start with an issue I am having. 2005 Legacy GT - Manual Trans. 144k No check engine lights. Issue started a couple weeks ago... Getting a surging or bogging issue under acceleration. Mostly seems to be lower RPM range. Some days its better than others. Did he easy stuff. Clean MAF and replace the air filter. Didn't seem to help. I am looking for recommendations on where to start or what to check. Thanks. Link to comment Share on other sites More sharing options...
FJuan Posted April 9, 2019 Share Posted April 9, 2019 Very common issue, it's either fuel pressure regulator or tuning. There's several threads on this topic, here's the better one. https://legacygt.com/forums/showthread.php/famous-stumble-fixedi-232816.html?highlight=stumble My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RottenJeeves Posted April 12, 2019 Author Share Posted April 12, 2019 Thanks. I will take a look. There is a lot of reading there. Not sure how I would take care of a tuning issue. Does that mean buying an AP? Link to comment Share on other sites More sharing options...
ttnio Posted April 12, 2019 Share Posted April 12, 2019 i am guessing a PO171(DTC). likely, a minute vaccum leak in your air intake. wait for the cel light to appear though, before starting to work on it. one more thing, stay away WOT and boost. you could be running lean... drive normal. Link to comment Share on other sites More sharing options...
RottenJeeves Posted April 15, 2019 Author Share Posted April 15, 2019 i am guessing a PO171(DTC). likely, a minute vaccum leak in your air intake. wait for the cel light to appear though, before starting to work on it. one more thing, stay away WOT and boost. you could be running lean... drive normal. Wait for the cel light to appear? The car is almost undrivable. There is a hill on the way to the work it bucks violently all the way up the hill. You guys probably know better but my gut tells me not to drive it till its fixed. I will probably start pulling things off this weekend. Link to comment Share on other sites More sharing options...
Berge56 Posted April 16, 2019 Share Posted April 16, 2019 I had some low rpm hesitation that was related to my OCV valves. You can start by cleaning them, but I ended up replacing them and now the car drives 100% better. Link to comment Share on other sites More sharing options...
RottenJeeves Posted April 18, 2019 Author Share Posted April 18, 2019 I had some low rpm hesitation that was related to my OCV valves. You can start by cleaning them, but I ended up replacing them and now the car drives 100% better. Interesting. I will see how hard they are to clean without breaking something. Link to comment Share on other sites More sharing options...
ttnio Posted April 18, 2019 Share Posted April 18, 2019 any DTC on this issue? Link to comment Share on other sites More sharing options...
RottenJeeves Posted April 19, 2019 Author Share Posted April 19, 2019 any DTC on this issue? Nope. Link to comment Share on other sites More sharing options...
ttnio Posted April 20, 2019 Share Posted April 20, 2019 no DTC, well i would check the fuel delivery system. Link to comment Share on other sites More sharing options...
