fishon1213 Posted April 1, 2019 Share Posted April 1, 2019 We were changing rotors and pads on our 97 Subaru today and came across this. Broken abs ring, might explain why the abs light is on. We recently purchased the car and just working on bringing it back to life. It seems I have three different options here. 1. Buy abs ring for $60, remove spindle, separate knuckle, press bearings... 2. Buy complete used spindle and replace. 3. Pull abs fuse, pull abs light and forget about it. Sent from my E6810 using Tapatalk Link to comment Share on other sites More sharing options...
Osei Posted April 1, 2019 Share Posted April 1, 2019 Option two is best choice. Less work, since you'd have to pull spindle and separate for #1. O. Link to comment Share on other sites More sharing options...
noahrexion Posted April 1, 2019 Share Posted April 1, 2019 Agreed, plus you can get a rust free unit. Link to comment Share on other sites More sharing options...
fishon1213 Posted April 1, 2019 Author Share Posted April 1, 2019 Thanks, it looks like I can get a used spindle for about $100. Just a couple questions... It looks like I just need to make sure it is for an abs car. Looks like they are all the same for legacy, impreza, outback, forester. Replacement procedure looks like... Remove axle nut, disconnect tie rod, ball joint, two strut bolts, unplug abs harness. Sound correct? Anything I'm missing? Is the abs plug inside the engine compartment? It is the front passenger btw. Thank you. Sent from my E6810 using Tapatalk Link to comment Share on other sites More sharing options...
fishon1213 Posted April 1, 2019 Author Share Posted April 1, 2019 Agreed, plus you can get a rust free unit.That would be nice, I think this car lived under the sea, haha. Sent from my E6810 using Tapatalk Link to comment Share on other sites More sharing options...
Osei Posted April 1, 2019 Share Posted April 1, 2019 The abs sensor just unbolts from back of hub. Its magnetic so it'll have pieces of metal attached. Clean You'll need an alignment afterwards. get FSM here:http://jdmfsm.info/Auto/Japan/Subaru/ O. Link to comment Share on other sites More sharing options...
