gregrock1989 Posted March 9, 2019 Share Posted March 9, 2019 05 OBXT 5MT. Had a engine rebuild done in December. Just started noticing this idle sound. Is that bottom or top end? Or something else? Thanks. https://youtu.be/cEmfUary-XY Link to comment Share on other sites More sharing options...
Carmania24 Posted March 9, 2019 Share Posted March 9, 2019 Personally I can not tell if it is from top or bottom. I would take it back to the shop that did your rebuild (if you got it done through a shop ofcourse). If not take it to a mechanic you trust and have them diagnose. Hopefully nothing too serious. Link to comment Share on other sites More sharing options...
gregrock1989 Posted March 9, 2019 Author Share Posted March 9, 2019 Yeah im going back there on Wednesday, just wanted to get some opinions from here first. I should also add that this noise is intermittent, which is going to make diagnosing it so much more fun (not) Link to comment Share on other sites More sharing options...
DaveWaters Posted March 10, 2019 Share Posted March 10, 2019 Could be timing belt tensioner. If you remove the timing belt cover on the drivers side and run the engine you would see it bouncing on the belt.. there are you tube vids about this. Link to comment Share on other sites More sharing options...
apexi Posted March 10, 2019 Share Posted March 10, 2019 It kind of sounds like the sound went away when you revved the engine. It's a shot in the dark, but I wonder if the timing belt tensioner is no good and rattling. Maybe see if the sound is coming from that area. The tensioner with the blue pulley can make a knocking sound as it bounces up and down Link to comment Share on other sites More sharing options...
gregrock1989 Posted March 10, 2019 Author Share Posted March 10, 2019 Awesome, tensioner definitely seems plausible to me, that's good news I guess. I'll tell them to have a look there. Thanks guys. Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 10, 2019 Share Posted March 10, 2019 Almost sounds like an exhaust leak. Have you put your hands around all of the flanges to see if they might be leaking? Wet your hands and you can find it immediately if it is, in fact, an exhaust leak. Link to comment Share on other sites More sharing options...
Gabo Posted March 10, 2019 Share Posted March 10, 2019 I would follow JMP's advice before taking any timing covers off. Link to comment Share on other sites More sharing options...
SesnaBlue Posted March 10, 2019 Share Posted March 10, 2019 (edited) How’s the oil level? I would check exhaust leaks for sure. That timing belt tensioner needs to be bench bled before installing. Maybe they didn’t bleed it correctly? Edited March 10, 2019 by SesnaBlue Link to comment Share on other sites More sharing options...
gregrock1989 Posted March 11, 2019 Author Share Posted March 11, 2019 Idk about the exhaust leak, because it makes the sound intermittently. Link to comment Share on other sites More sharing options...
bigfatdaddy Posted March 11, 2019 Share Posted March 11, 2019 (edited) Could use a stethoscope to probe around the engine to see where the noise is loudest? Something like this: https://www.amazon.ca/Mechanics-Stethoscope-Diagnostic-Automotive-Hearing/dp/B07HGB2V13/ref=sr_1_fkmrnull_3?keywords=engine+stethoscope&qid=1552302270&s=industrial&sr=1-3-fkmrnull Edited March 11, 2019 by bigfatdaddy Link to comment Share on other sites More sharing options...
gregrock1989 Posted March 11, 2019 Author Share Posted March 11, 2019 Oil level is fine. I check it every week and havent lost a drop since the rebuild Link to comment Share on other sites More sharing options...
