SRGL Posted February 20, 2019 Share Posted February 20, 2019 New to the forums, hope this is the correct place to post this. Will the JDM kouki/facelift tail lights (will insert photo of lights) fit an 05 GT Wagon? And what will be needed for the swap, if anything. Link to comment Share on other sites More sharing options...
DoctorDaveLGT Posted February 20, 2019 Share Posted February 20, 2019 Completely plug and play. You won't need the side marker bulbs with these. I removed the bulb, taped the empty socket and tucked it in when installing rather than snipping the wires so USDM lights can be thrown back on at any time. Link to comment Share on other sites More sharing options...
jkaic Posted February 20, 2019 Share Posted February 20, 2019 IIRC the tabs for the brake light socket were slightly off and didn't fit snug, but they do go in. Oh and if you check Croooober they're often on sale for dirt cheap, if you don't mind shipping time and cost. Link to comment Share on other sites More sharing options...
bobglaub Posted February 22, 2019 Share Posted February 22, 2019 I have some on mine. Mine came with the lights and wire harness. I pulled the interior back inside and disconnected the old one and plugged in the JDM ones. Worked perfectly. I was installing an STI fuel pressure control module anyway so I had to pull the interior back on one side anyway. But like doctordavelgt said, plug and play. Link to comment Share on other sites More sharing options...
