Lux Posted January 22, 2019 Share Posted January 22, 2019 New to me. If I'm pulling my motor to replace headgaskets; what else should I replace just on general principle? Oil pan gaskets. Banjo filters. Oil sending tube? I've been poring over multiple forums but found nothing comprehensive. Turbo seals leaking. Fix or swap? She's been lowered and I need to go back up. Options? @ampmcv Link to comment Share on other sites More sharing options...
Holla Posted January 22, 2019 Share Posted January 22, 2019 What is the situation that the head gaskets need to be replaced? Are the turbo seals actually leaking? I’d get the heads decked and to the timing belt and water pump. You’re best bet for suspension would probably be an oem Bilstein setup like the car came with. What is the car currently on and what do you want out of it? Link to comment Share on other sites More sharing options...
Lux Posted January 22, 2019 Author Share Posted January 22, 2019 Leaking oil. Like 2 qts. every 1000 mi. H&R lowering springs. I'd like something close to stock. I live in Chattanooga and I'm leery of letting just anyone deck my heads. Any suggestions? Sent from my E6833 using Tapatalk @ampmcv Link to comment Share on other sites More sharing options...
Lux Posted January 22, 2019 Author Share Posted January 22, 2019 Yes, sorry. The seals are leaking. Sent from my E6833 using Tapatalk @ampmcv Link to comment Share on other sites More sharing options...
Max Capacity Posted January 22, 2019 Share Posted January 22, 2019 Leaking oil. Like 2 qts. every 1000 mi. H&R lowering springs. I'd like something close to stock. I live in Chattanooga and I'm leery of letting just anyone deck my heads. Any suggestions? Sent from my E6833 using Tapatalk So are your head gaskets leaking that much oil...or are the valve covers leaking ? New oil return hose from the turbo remove both banjo filters Aisin timing belt kit see JmP's sticky up top about, https://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238.html Lot's of good info there. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
m sprank Posted January 23, 2019 Share Posted January 23, 2019 Just ship me the car. I might get to it eventually. In the mean time, it stops you from spending money. Link to comment Share on other sites More sharing options...
Lux Posted January 23, 2019 Author Share Posted January 23, 2019 Just ship me the car. I might get to it eventually. In the mean time, it stops you from spending money. :lol:Thanks!!! All my troubles are over, dude! @ampmcv Link to comment Share on other sites More sharing options...
m sprank Posted January 24, 2019 Share Posted January 24, 2019 See. Helpful service with a smile still exists. Millenials can specialize in being incompetant and old farts like me will be able to hold jobs into retirement age. Lol. Just convince the masses to gift me their problem cars. Link to comment Share on other sites More sharing options...
Lux Posted February 3, 2019 Author Share Posted February 3, 2019 Deal fell through. I'm going to post what I got. @ampmcv Link to comment Share on other sites More sharing options...
