anotherjimmylee Posted January 15, 2019 Share Posted January 15, 2019 What up pipes will fit 2005 outback xt? Assuming LGT, Wrx, STI will fit, but what model years 2004-2007? Any particular up pipes you recommend? Trying to keep it under $100 so eBay and knock off are okay. Also looking for a vf52 turbo if anyone has one available. Sent from my SM-N950U using Tapatalk Link to comment Share on other sites More sharing options...
spec.B Dream Posted January 15, 2019 Share Posted January 15, 2019 05-09 LGT and 09-14 WRX should fit as their turbos are interchangeable. If you want to go cheap, get a used 07-09 LGT as they are catless. I'm still running my stock up pipe without issue. Link to comment Share on other sites More sharing options...
Notorious Posted January 15, 2019 Share Posted January 15, 2019 Find an OEM 07-09 which will fit great or get Megan Racing’s up pipe but at least get Grimmspeed’s gaskets because I would expect to run into fitment issues going for cheaper options. I’m running Invidia’s without the EGT bung on my VF52 and have no issues. Link to comment Share on other sites More sharing options...
relative4 Posted January 15, 2019 Share Posted January 15, 2019 Assuming you want catless, as you should, the best pipe for the money is a used STi, from ANY year of STi. Post a WTB on NASIOC, you'll get numerous offers. Expect to pay around $70-80 shipped. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 15, 2019 Share Posted January 15, 2019 I'll give you a hint, bolt the turbo to the up pipe. Oh yea, get a new oil return hose too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Sparkey Posted January 17, 2019 Share Posted January 17, 2019 What up pipes will fit 2005 outback xt? Assuming LGT, Wrx, STI will fit, but what model years 2004-2007? Any particular up pipes you recommend? Trying to keep it under $100 so eBay and knock off are okay. Also looking for a vf52 turbo if anyone has one available. I disagree. Very few knock off pieces are worth it. They come back and bite you later if not right after buying them. I bought a 15' STi up pipe off ebay for $60. On that note, you can look for virtually any OEM STi pipe in addition to the 07+ LGT and 08+ WRX's - cheap, effective, has a flex secton. heres one for $70 shipped as others have said, be sure to get some of the small things like new gaskets, oil return hose, pull the filters if not already, ect.. 05' LGT, ZFD Built 5MT, Stage 2 Cryotune 91/E85, 170,000mi running BRotella T6 and Ecoguard S4615 filters. Link to comment Share on other sites More sharing options...
limberpineobxt Posted February 6, 2019 Share Posted February 6, 2019 I have a rebuilt VF52 that I'm not using. Message me if you want to chat about it. Link to comment Share on other sites More sharing options...
