computersoc Posted January 14, 2019 Share Posted January 14, 2019 113800 miles. If I coast down, anywhere from 20MPH to 5MPH I get a whistle whistle whistle noise which sounds like it's coming from a front tire. Could be described as a bird chirp noise. What could be the issue? Link to comment Share on other sites More sharing options...
CDKJudoka Posted January 14, 2019 Share Posted January 14, 2019 Could be brake pads are worn where it is slightly hitting the sensor. 2014 Legacy 2.5i 6M - FB25 w/ a 6 speed 2002 Impreza 2.5TS - EJ251 w/ a 5 speed (The Stormtrooper) Link to comment Share on other sites More sharing options...
computersoc Posted January 14, 2019 Author Share Posted January 14, 2019 Could be brake pads are worn where it is slightly hitting the sensor. Just to clarify, I'm not hitting the brakes. I'm coasting. Happens when speeding up from 5mph to 20mph also. Doesnt happen outside that speed range. Link to comment Share on other sites More sharing options...
cww516 Posted January 14, 2019 Share Posted January 14, 2019 Do you get that same noise if you push on the pedal? If not, it could be the squeaker like CDKJudoka suggested, or possibly a pad dragging or something like that. Link to comment Share on other sites More sharing options...
