Controlling boost
If you're running stock turbo/boost levels or slightly higher, an aftermarket 3 port EBCS isn't necessary.
In short, tuners prefer them because they react slightly faster than the oem 2 port EBCS system. 3 port systems can maker it easier to tune and control boost as it is increased above stock levels.
Here is a simple and effective article:
https://blog.edgeautosport.com/3-port-electronic-boost-control-solenoid-what-and-why
  • 3 weeks later...
They are all rebranded MAC solonoids. Get whichever has a mounting bracket and fittings you like.
The bracket and fittings on the Cobb are aligned best for the LGT. I bought a Grimmspeed as directed, and it was a huge pain cause all the fittings were pointing the wrong way and I had to route them 180 degrees. Plus one of the fittings was the wrong size and I had to rig up an adapter.
Sent from my SM-J700T using Tapatalk
