fizzlefish Posted November 1, 2018 Share Posted November 1, 2018 Found I was a quart low this morning. LGT has been eating oil. I am looking into putting a oil gauge in the car since the stock doesn't tell you until its too late. Not sure which sensor to go with or what thread type I need. NPT or BSPT? I was hoping there is a kit i can just buy with it all included. Any recommendations? Thanks. Link to comment Share on other sites More sharing options...
Guest Posted November 1, 2018 Share Posted November 1, 2018 I recommend this kit: https://www.fastwrx.com/products/remote-oil-pressure-sending-kit It connects in a plugged port in a galley and the rear of the block and allows you to mount the sender remotely. I use PLX gauge (plxdevices.com). Link to comment Share on other sites More sharing options...
Max Capacity Posted November 1, 2018 Share Posted November 1, 2018 That’s a nice looking kit. I recommend a copper line and a direct reading gauge. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
fizzlefish Posted November 1, 2018 Author Share Posted November 1, 2018 That’s a nice looking kit. I recommend a copper line and a direct reading gauge. any suggestions on which one or should the one posted above work? Thanks Link to comment Share on other sites More sharing options...
Cutlassjim Posted November 1, 2018 Share Posted November 1, 2018 As an FYI this really won't tell you anything until it's too late either. Unless you have it set to interrupt your ignition when oil pressure drops below warm idle pressure it's just a false sense of security. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 1, 2018 Share Posted November 1, 2018 (edited) I would find a good direct reading oil pressure gauge from Summit or Jegs, etc. IMO keep it simple, no electronics, you will get a good reading that you can check every time the engine is at idle. Just do a google search and see what pops up. You'll find prices from $15 - XXX. They will all read oil pressure, just find one that fits your budget. Edited November 1, 2018 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tronic Posted November 1, 2018 Share Posted November 1, 2018 I just have a cheap autoguage rip off one in my Toyota. It works well but the senders are pretty cheap and its hard to get a decent quality one as well. Mine lasted like 8 years but its pretty close to the Turbo downpipe so what else would you expect. Would stick to electronic and it needs to be done properly or else you could create the very situation your trying to avoid. Very useful to have as it verify s not only the oil pump but the oil bypass valve. Also good for monitoring the viscosity of you oil and general engine health. Link to comment Share on other sites More sharing options...
BrainStormeR Posted November 1, 2018 Share Posted November 1, 2018 I've got one, but how would it tell if you're low? Once, I went really beyond the LOW dot (dipstick barely wet on the tip) but the gauge was showing normal readings, and when I topped up - no change in readings. Link to comment Share on other sites More sharing options...
Tronic Posted November 2, 2018 Share Posted November 2, 2018 I've got one, but how would it tell if you're low? Once, I went really beyond the LOW dot (dipstick barely wet on the tip) but the gauge was showing normal readings, and when I topped up - no change in readings. You should not get in that situation, you need to check the oil level now and again. The pressure gauge is for sudden loss of oil pressure or your sump plug drops out. Its handy to have both the gauge and the stock oil pressure warning light for redundancy/double check. If the gauge is zero and the dash light is on you had better stop the engine real quick. Link to comment Share on other sites More sharing options...
Guest Posted November 2, 2018 Share Posted November 2, 2018 ^ truth. Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 3, 2018 Share Posted November 3, 2018 I think OP wants an oil "level" gauge. I've not seen one aftermarket. Some of the newer cars have them as OE but not seen one you can add to an existing car. Link to comment Share on other sites More sharing options...
Tronic Posted November 4, 2018 Share Posted November 4, 2018 I think OP wants an oil "level" gauge. I've not seen one aftermarket. Some of the newer cars have them as OE but not seen one you can add to an existing car. Yes but they are typically unreliable even if its factory fitted. Its far easier to just pull out the dipstick and check it and its pretty fail safe unless your blind. Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 4, 2018 Share Posted November 4, 2018 Yes but they are typically unreliable even if its factory fitted. Its far easier to just pull out the dipstick and check it and its pretty fail safe unless your blind. Agree. Link to comment Share on other sites More sharing options...
