kadegrizzard Posted October 27, 2018 Share Posted October 27, 2018 so I'm in the process of getting all of my parts for my vf52 swap on my 05 lgt. I ordered the up pipe from Ebay for about 40$ and was told that it would fit the vf52. I got my vf52 in the mail today and the up pipe does not line up with the turbo. is there a difference in size from the vf40 to the vf52? is it because I bought a cheap up pipe? is it both? I need some help Sent from my SM-G930V using Tapatalk Link to comment Share on other sites More sharing options...
Gex Posted October 27, 2018 Share Posted October 27, 2018 Seriously? Link to comment Share on other sites More sharing options...
DaveWaters Posted October 27, 2018 Share Posted October 27, 2018 I guess the million dollar question here is are you planning on doing the work yourself or having a shop do it? In the pic you are comparing the turbo to intercooler flange to the up pipe to exhaust manifold flange. Don’t take this the wrong way...We’re here to help but ya kinda need to know some basics first. Google is your friend. Link to comment Share on other sites More sharing options...
Max Capacity Posted October 27, 2018 Share Posted October 27, 2018 (edited) Sorry to LAUGH but you may want to flip the turbo over and the up pipe over and see if the 5 bolt flange's match up. Another tip when it comes time to assemble, do not use the studs in the up pipe. I use bolts that I got from the parts guys at the dealership. Just tell them you want 5 bolts that bolt the up pipe support bracket to the block. Leave the turbo loose on the up pipe until you have the tmic and TB hose lined up and turbo inlet hose to turbo, and tightened. Then tighten the 5 bolts and put the down pipe on. Use anti-seize compound on all bolt threads and nut threads. Do not over tighten the bottom nut on the DP flange. You need a open end 14mm wrench for it. if you over tighten it...you will pay for that mistake the next time you try to remove it. Install a new oil return hose from turbo to back of head. Remove the filter in the banjo bolt for the turbo oil feed from the back of the head while the up pipe is out. Lot's to learn, ask us before you do something. I think you can see pictures on my turbo bolted to the up pipe in my "click Here" link in my sig below. Here, I'll make it easy, see post's 125, 134 & 146 https://legacygt.com/forums/showthread.php/got-some-new-stuff-engine-r-r-184106p4.html Edited October 27, 2018 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
