FLlegacy Posted October 8, 2019 Share Posted October 8, 2019 Not currently but with track use, I'd like to have the piece of mind.So you want to fix a problem you don't have? Maybe you could get someone to custom make you one. Sent from my SM-G965U using Tapatalk Link to comment Share on other sites More sharing options...
Humble Rumble Posted October 8, 2019 Share Posted October 8, 2019 So you want to fix a problem you don't have? Maybe you could get someone to custom make you one. Sent from my SM-G965U using Tapatalk More like address it before it has a chance to become a problem. I'd likely do the STI thermostat at the same time. Custom is possible but likely pricey, though there's a guy in the FB group talking about it for his H6. He's a very enterprising sort. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
Scubaboo Posted October 9, 2019 Author Share Posted October 9, 2019 Yea, thankfully the 2015+ WRX shares more than a couple parts with our gen Sent from my ONEPLUS A5000 using Tapatalk Thankfully! I had no idea that the rad worked, I did learn on here the intercooler does, and recently, the front seat assembly. Nice to have more modding options! Link to comment Share on other sites More sharing options...
Scubaboo Posted October 9, 2019 Author Share Posted October 9, 2019 (edited) So you want to fix a problem you don't have? Maybe you could get someone to custom make you one. Sent from my SM-G965U using Tapatalk I notice that a lot here. Heck, I saw some dude here change the shape of a perfectly functional steering wheel! Edited October 9, 2019 by Scubaboo Link to comment Share on other sites More sharing options...
FLlegacy Posted October 9, 2019 Share Posted October 9, 2019 I notice that a lot here. Heck, I saw some dude here change the shape of a perfectly functional steering wheel! I need more knee room, lol! Tall people problems! On serious side, I can't recall a correctly functioning 3.6 having overheating problems even when pushed hard. It could be the lack of crossover pipe really helps. Also, if you are serious about this mod find a really cheap used radiator and take it apart to see if the difference is only the second inlet from the other side of the engine, if it is then have another inlet welded onto an aluminum radiator and be done. Link to comment Share on other sites More sharing options...
Scubaboo Posted October 9, 2019 Author Share Posted October 9, 2019 Ah, I'm a shorty so that never crossed my mind Yeah, I think even the turbos dont really have a problem when everything is functioning properly. I do like the aluminum rads have aluminum end tanks and are welded. I've had OE style rads crack end tanks or leak at the crimps on a variety of cars, I like that it cant happen here. As for cooling, these rads do lower the average temps a bit but really need fan reprogramming to work best. Come to think of it, maybe fan reprogramming with a stock rad may do just as well? What really gave me a big drop in temps was an engine oil cooler system. Even with a 100c oil thermostat, the little bypass flow really dropped oil and coolant temps on the average. It may be too effective as it takes me 15mins to get to 80c oil temp, I am thinking of swapping out the STI coolant thermostat for the OE one, it may get everything warmed up faster? Link to comment Share on other sites More sharing options...
FLlegacy Posted October 9, 2019 Share Posted October 9, 2019 Another way to maximize cooling in the radiator would be to go for an auxiliary trans-cooler with thermostatically controlled fan and remove the radiator from the trans cooling circuit. If you are really concerned with straining the engine cooling the trans will probably be feeling it before the engine. Link to comment Share on other sites More sharing options...
Scubaboo Posted October 9, 2019 Author Share Posted October 9, 2019 Yeah thats another thing that may help on the edge of cooling efficiency, I'm not going that far though lol! Link to comment Share on other sites More sharing options...
shi_daniel Posted January 29, 2020 Share Posted January 29, 2020 (edited) A 2015+ WRX radiator will work for us since they also don't have the extra hose that the STIs do. I have the Koyorad VH091662. It's a drop in plug and play. Another FB 5th gen owner installed a CSF radiator for the 08+ STi Sent from my ONEPLUS A5000 using Tapatalk Do you know if the following radiator can be used in a 2011 Legacy GT? https://www.mishimoto.eu/subaru-wrx-performance-aluminium-radiator-2015.html I don't wanna deal with any kind of mods...just replacing the original one for a full alluminum radiator. I realize that for a fifth gen, all dealers didn't provide a specific radiator :-( Edited January 29, 2020 by shi_daniel Link to comment Share on other sites More sharing options...
Zee199969 Posted January 29, 2020 Share Posted January 29, 2020 Your link doesn't work for me, but I would assume that all 2015+ WRX radiators would fit USDM 5th gen GTs/2.5i. I do see you're from Brazil, so I am unsure if there are any differences between our radiator and yours. My "Build" Link to comment Share on other sites More sharing options...
shi_daniel Posted January 31, 2020 Share Posted January 31, 2020 Hi Zee199969! I've sent a PM for you! I think your Box is full :-O Anyway, I see you've installed a Koyo VH091662 in the following link: https://legacygt.com/forums/showthread.php/did-you-do-your-5th-gen-todayii-v4-267765.html?p=5896685#post5896685) Could you tell me if you had any problem with clearence between Fan, hose or anything else? Can I use a stock hose? Installation is like replacing the stock rad by another identical? VH091662 is 20mm thicker than stock rad :-O I see some differences between your Koyo and the stock one. There are 2 tabs in the bottom of stock radiator that Koyo don't have (Koyo's bottom part just have points to install Fans and two pins..stock radiator have two tabs more. Stock rad can be seen in the following post: https://legacygt.com/forums/showthre...gt-276124.html I'd like to know if you bought Samco Hose because the original one could not be used. I live in Brazil and my 11 LGT is a JDM model. I think USDM and JDM use the same radiator, but I'm not 100% sure. Thanks for your help! PS: Sorry for my terrible english :-( Link to comment Share on other sites More sharing options...
Scubaboo Posted February 2, 2020 Author Share Posted February 2, 2020 ^Daniel, check the pictures in my thread, my car is JDM spec too. I have pics of the rad and everything mounted on the rad before putting it all in. It may help. Link to comment Share on other sites More sharing options...
BigSqueeze Posted April 30, 2020 Share Posted April 30, 2020 Would the Megan Racing Radiator Subaru WRX & STi [2 Row] (2008-2014) MR-RT-SI08 radiator work for a 2012 Legacy 2.5i premium CVT? I think I need to add a CVT cooler which isn't a problem. I replaced the hoses and did a flush. Went to replace the thermostat and housing before refilling with coolant and I think the radiator is seeping. https://shop.redline360.com/products/megan-racing-radiator-subaru-wrx-sti-2-row-2008-2014-mr-rt-si08?variant=28753299669072¤cy=USD&gclid=EAIaIQobChMI4MCZvfqJ6QIVIx-tBh1EvQ_UEAQYByABEgJ4jvD_BwE Link to comment Share on other sites More sharing options...
Scubaboo Posted April 30, 2020 Author Share Posted April 30, 2020 Would the Megan Racing Radiator Subaru WRX & STi [2 Row] (2008-2014) MR-RT-SI08 radiator work for a 2012 Legacy 2.5i premium CVT? I think I need to add a CVT cooler which isn't a problem. I replaced the hoses and did a flush. Went to replace the thermostat and housing before refilling with coolant and I think the radiator is seeping. https://shop.redline360.com/products/megan-racing-radiator-subaru-wrx-sti-2-row-2008-2014-mr-rt-si08?variant=28753299669072¤cy=USD&gclid=EAIaIQobChMI4MCZvfqJ6QIVIx-tBh1EvQ_UEAQYByABEgJ4jvD_BwE I cant say because I dont know if there are relevant cooling system differences between turbo and non turbo engines. If they happen to be the same, you can check BBPeik's thread on installing an STI-spec radiator into a GT here: https://legacygt.com/forums/showthread.php/mishimoto-sti-08-radiator-install-255262.html Link to comment Share on other sites More sharing options...
