mthurmond Posted November 6, 2005 Share Posted November 6, 2005 I drove home last night and when I pulled in the garage the car was popping more than usual (heat popping). I opened the hood and where you can see through the heat shelding the Exhaust manifold (not the shielding) pre-turbo was glowing red. It's not a night thing either, I checked this afternoon and I can see the glowing in my garage with the door open and sun coming in. My question is this: should the exhaust manifold get hot enough to glow? Link to comment Share on other sites More sharing options...
edmundu Posted November 6, 2005 Share Posted November 6, 2005 Yeah, that's normal! Cast Iron will start glowing somewhere around 1250 degrees, and our exhaust does run around 1400-1450 pretty regularly. I just don't advise running the car hard, and then immediately shutting down. Just drive easy for the last mile or 2. Link to comment Share on other sites More sharing options...
jmanzs Posted November 6, 2005 Share Posted November 6, 2005 yes if you drive it hard enough! Just give the turbo a couple of minutes to cool before turning the car off!!! Link to comment Share on other sites More sharing options...
mthurmond Posted November 6, 2005 Author Share Posted November 6, 2005 Great, Thanks! Just got the car back from major engine work at the dealership and so I'm watching things very closely right now. Link to comment Share on other sites More sharing options...
MUD Posted November 6, 2005 Share Posted November 6, 2005 Great info for me too. This is my first FI car. I was used to NA.....and when you get a glowing cat.... it means there's a blockage in the flow that needs to be addressed! Thanx! It is the disposition of men to desire that which he cannot have, hence my un-quenchable wet desire for Shakira! Link to comment Share on other sites More sharing options...
Skillz Posted November 6, 2005 Share Posted November 6, 2005 Great, Thanks! Just got the car back from major engine work at the dealership and so I'm watching things very closely right now. What kind of "major engine work"? Link to comment Share on other sites More sharing options...
mthurmond Posted November 6, 2005 Author Share Posted November 6, 2005 Reseat the valves due to excessive leakage in the #1 cylinder. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted November 6, 2005 Share Posted November 6, 2005 WTF? My exhaust doesn't glow. Link to comment Share on other sites More sharing options...
mach_six Posted November 6, 2005 Share Posted November 6, 2005 WTF? My exhaust doesn't glow. Then again you don't run plutonium in your engine. Link to comment Share on other sites More sharing options...
mthurmond Posted November 6, 2005 Author Share Posted November 6, 2005 The glowing on my car isn't immediately noticable unless it's dark outside, then you see the glow peeking out from the cracks in the heat shielding. If you know what you're looking for, and it glows like mine, you can see it if your car's in the shade. Link to comment Share on other sites More sharing options...
team23jordan Posted November 6, 2005 Share Posted November 6, 2005 get an aftermarket header then ceramic coated it Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
GardenWeasel Posted November 6, 2005 Share Posted November 6, 2005 For anyone who wants to see some glowing: http://badger-5.com/bin/evo7glowing.wmv Link to comment Share on other sites More sharing options...
PhilT Posted November 6, 2005 Share Posted November 6, 2005 Yowser, that is not good. Everytime it gets that hot, then cools, the structure of the casting becomes weaker, until one day........CRACK ! Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
liquidiq Posted November 6, 2005 Share Posted November 6, 2005 Yowser, that is not good. Everytime it gets that hot, then cools, the structure of the casting becomes weaker, until one day........CRACK ! Your turbo glows when you are running it hard. You better replace it, it's gonna crack!! OMG! Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted November 7, 2005 Share Posted November 7, 2005 Then again you don't run plutonium in your engine. What did I tell you about giving away trade secrets? Link to comment Share on other sites More sharing options...
starlabs Posted November 7, 2005 Share Posted November 7, 2005 For anyone who wants to see some glowing: http://badger-5.com/bin/evo7glowing.wmv -=- Livin life at 140 BPM -=- Link to comment Share on other sites More sharing options...
Skillz Posted November 7, 2005 Share Posted November 7, 2005 Reseat the valves due to excessive leakage in the #1 cylinder. How old is your car? How did you know what was happening? Link to comment Share on other sites More sharing options...
mthurmond Posted November 7, 2005 Author Share Posted November 7, 2005 1 year. ~22000 miles. Stuttering, hesitation and bucking on acceleration. According to the repair order: "Per subaru tech line, performed cylinder leak down test." The teardown also revealed significant carbon buildup in the combustion chambers. Link to comment Share on other sites More sharing options...
jmanzs Posted November 7, 2005 Share Posted November 7, 2005 For anyone who wants to see some glowing: http://badger-5.com/bin/evo7glowing.wmv Wow!! Now thats some glowing!!!! Link to comment Share on other sites More sharing options...
boostsr20 Posted November 7, 2005 Share Posted November 7, 2005 Looked like a 5th gear Dyno run.... WTF? Link to comment Share on other sites More sharing options...
Ridgeracer Posted November 7, 2005 Share Posted November 7, 2005 1 year. ~22000 miles. Stuttering, hesitation and bucking on acceleration. According to the repair order: "Per subaru tech line, performed cylinder leak down test." The teardown also revealed significant carbon buildup in the combustion chambers. Sounds like you might of been using poor fuel.. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
PhilT Posted November 7, 2005 Share Posted November 7, 2005 Your turbo glows when you are running it hard. You better replace it, it's gonna crack!! OMG! If your turbo glows that colour, then you better start looking for a new one, the up pipe cat is about to disintegrate and go through it. From the chart below, I would say that guy's header was around 950 deg C, around 1750 deg F. At that point, the crystalline structure of the casting is permanently altered and becomes very brittle unless it is cooled down in a controlled way. The turbo might glow a blood red, or even a cherry red, but most definately not orange. http://www.westyorkssteel.com/images/htchar1.gif Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
mthurmond Posted November 7, 2005 Author Share Posted November 7, 2005 Video and colors can be funky. The color you saw on your screen may not have been what the manifold actually was. Link to comment Share on other sites More sharing options...
adamgt Posted November 7, 2005 Share Posted November 7, 2005 I've seen a turbo and exhaust manifold glowing light red to orange before... granted it was not on anything even remotely similar to an LGT. it was an International DT466 (466 cubic inches or 7.5L) diesel engine (think really big dump truck) on an engine dyno. Maxed out at 24psi boost, full load, at about 2100rpm. the dyno said it was producing in the neighborhood of 1150 ft lbs of torque, and i believe it considering that it was twisted over in its mounting cradle and picking up two of the stand's legs off the ground!! still one of the coolest things I have ever seen. Link to comment Share on other sites More sharing options...
BLACKonBLACK Limited Posted November 7, 2005 Share Posted November 7, 2005 You Think Thats HOT? Ill put the evo clip to shame F1 Fire UP: http://users.zoominternet.net/~jonlauer/f1fireup.mpeg Link to comment Share on other sites More sharing options...
