KND Posted July 24, 2018 Share Posted July 24, 2018 I found a filter hidden behind the battery? Is it a oil filter or fuel filter? Link to comment Share on other sites More sharing options...
Infosecdad Posted July 24, 2018 Share Posted July 24, 2018 Picture? There isn’t a stock filter behind the battery on an 05 GT LTD, it’ll be something that some one added. Link to comment Share on other sites More sharing options...
DaveWaters Posted July 24, 2018 Share Posted July 24, 2018 Transmission filter for 5eat Link to comment Share on other sites More sharing options...
Max Capacity Posted July 24, 2018 Share Posted July 24, 2018 ^ x2 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Infosecdad Posted July 24, 2018 Share Posted July 24, 2018 Nice, that's a new one for me I've only played with the manual versions. I stand corrected. Link to comment Share on other sites More sharing options...
KND Posted July 26, 2018 Author Share Posted July 26, 2018 Thanks guys. Never knew it was there. Link to comment Share on other sites More sharing options...
m sprank Posted July 26, 2018 Share Posted July 26, 2018 Tip on changing rhe filter... place a rag or two under the filter when removing. Easier to catch the dripping atf than to clean it out of the wheel well liner. Make sure the old filter oring came off. Seen old orings stacked causing leaks before. A decent set of channel locks is your friend for removal/torque. Most wont have other tools. Link to comment Share on other sites More sharing options...
