DustinEgle Posted July 17, 2018 Share Posted July 17, 2018 2008 Subaru Legacy GT. The car is my daily driver and I've never tracked it. I plan on taking it a fee times eventually but it's mostly just my daily. I do a little bit of spirited street driving but that's mostly it. What brake fluid do you guys use in your LGT's? I'm doing a complete flush when I put my new rotors and pads on. Link to comment Share on other sites More sharing options...
JF1GG29 Posted July 17, 2018 Share Posted July 17, 2018 In my opinion, Castrol SRF is, hands down, the best commonly available brake fluid. If that is too spendy, there are plenty of options: Motul RBF 660/600, ATE Type 200, Motul DOT 5.1, etc. Link to comment Share on other sites More sharing options...
JoeSkye Posted July 17, 2018 Share Posted July 17, 2018 Any Dot 4 fluid with a 450+ boiling point. Do NOT get silicone-based brake fluid. It will react with the oil fluid and ruin lots of expensive parts. Most Dot 5 fluids are silicone. Motul Dot 5.1 mentioned above is not. It is safe to run. That being said, I run Amsoil Series 600 Dot 4 in my cars. Link to comment Share on other sites More sharing options...
fedaykin Posted July 18, 2018 Share Posted July 18, 2018 Super DOT 4 Link to comment Share on other sites More sharing options...
m sprank Posted July 18, 2018 Share Posted July 18, 2018 ATE Type 200. Best fluid for the money hands down. Link to comment Share on other sites More sharing options...
stevenva Posted August 5, 2018 Share Posted August 5, 2018 NEW brake fluid on your daily. Change with more NEW every 2 years. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
08SpecB_DE Posted August 5, 2018 Share Posted August 5, 2018 What benefits do you guys see from running all these different types of brake fluid? I can see benefits on the track but for DD? Link to comment Share on other sites More sharing options...
stevenva Posted August 5, 2018 Share Posted August 5, 2018 None will be noticed on a daily. They are all just hydraulic fluids with a high boiling temp. The're all hygroscopic and must be changed with new at regular intervals to prevent internal corrosion. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
m sprank Posted August 5, 2018 Share Posted August 5, 2018 It might be a placebo, but have had scores of customers comment on how much better their brakes feel after switching to ATE. I flush all dd customers brake fluid at 30k intervals here in So Cal. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted August 6, 2018 Share Posted August 6, 2018 Thats what i figured but i wasnt sure if i was missing something. Moisture content makes a difference. I've seen fresh bottles of dot 3 have 4+% moisture Link to comment Share on other sites More sharing options...
JF1GG29 Posted August 6, 2018 Share Posted August 6, 2018 I think the Castrol SRF absorbs less moisture than most brake fluids. It may be placebo, but I've found I can run it longer and keep great pedal feel. Otherwise, I change/flush fluid every year with standard DOT 4 from the parts store. On a DD? Probably not going to need the SRF, but the ATE is a worthy option. Link to comment Share on other sites More sharing options...
