DBA 4000 rotors and Hawk pads: Best brake fluid to use?
DustinEgle
2008 Subaru Legacy GT. The car is my daily driver and I've never tracked it. I plan on taking it a fee times eventually but it's mostly just my daily. I do a little bit of spirited street driving but that's mostly it. What brake fluid do you guys use in your LGT's? I'm doing a complete flush when I put my new rotors and pads on.
Any Dot 4 fluid with a 450+ boiling point. Do NOT get silicone-based brake fluid. It will react with the oil fluid and ruin lots of expensive parts. Most Dot 5 fluids are silicone. Motul Dot 5.1 mentioned above is not. It is safe to run.
That being said, I run Amsoil Series 600 Dot 4 in my cars.
  • 3 weeks later...
None will be noticed on a daily. They are all just hydraulic fluids with a high boiling temp. The're all hygroscopic and must be changed with new at regular intervals to prevent internal corrosion.
RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles
I think the Castrol SRF absorbs less moisture than most brake fluids. It may be placebo, but I've found I can run it longer and keep great pedal feel.
Otherwise, I change/flush fluid every year with standard DOT 4 from the parts store.
On a DD? Probably not going to need the SRF, but the ATE is a worthy option.
