giiyanman Posted May 26, 2018 Share Posted May 26, 2018 How should my temperature gauge read if everything is running splendidly? As reference this is how my temp gauge normally reads: Is this normal? Also I've noticed that only one of my radiator fans are running when it turns on. How do I check if one of my fans are busted? Link to comment Share on other sites More sharing options...
Brighton96 Posted May 26, 2018 Share Posted May 26, 2018 Only one fan will ever come on under normal conditions, the other fan is for the A/C. Also the temp gauge looks fine, it doesn't really matter where the needle is, as long as it's consistently in the same place when the cooling system is perfect. Link to comment Share on other sites More sharing options...
RumbleRumble Posted May 26, 2018 Share Posted May 26, 2018 yeah that's normal. Mine even goes to the middle when idling on a hot day. The other fan should come on with the A/C on. The first fan comes on by thermostat. Link to comment Share on other sites More sharing options...
