bdcvg Posted May 18, 2018 Share Posted May 18, 2018 I have JDM Rev A Bilsteins now and they are a little stiff for the roads around here. Has anybody cut Their stock OBXT struts to fit Legacy GT Koni's ? I have read all the Koni install info and can't find a reason it won"t work. Link to comment Share on other sites More sharing options...
rougeben83 Posted May 18, 2018 Share Posted May 18, 2018 The only problem I see is that the OB has a 1 inch taller strut body - you're only cutting the front for the inserts, leaving you with Legacy-sized struts in the rear (maybe a 1+ in spacer in the rear tophats would compensate?). Link to comment Share on other sites More sharing options...
bdcvg Posted May 18, 2018 Author Share Posted May 18, 2018 That's My question. Any reason the OB struts couldn't be cut to LGT length. The length below the spring purchase appears to be the same. Link to comment Share on other sites More sharing options...
