xtea Posted May 9, 2018 Share Posted May 9, 2018 I have spec b take offs with swifts. Was using it as my winter set up and keeping my coilovers for summer. I actually like the ride height of my spec b take off bilsteins with swifts. I scrape enough that I don't need to go lower with coilovers at all. I liked my coilovers last year which I only used for about a month before winter. FA 500s with 8k/8k swift springs if anyones curious. But I really hate the adjustability of coilovers. I spent far too much time tweaking everything. So I am thinking about selling my coilovers and getting some Bilstein b6 HD'S. My only concern is that they might be too soft. On my coilovers I run 8k/8k springs with them tightened to almost full stiff. The ride is great and with 440whp (soon to be 500whp with a new turbo) I just want to make sure the HDs can handle it. I don't track my outback. I just looking to have nice daily ride with enough stiffness to kill lean and squat. I don't want to mess with konis. I rode on a guys legacy with them and thought they were too soft. After typing all this I am thinking I may be better off using my coils. But I love my spec b bilstein performance I just want the stiffness to be closer to BMW or Mazda. Link to comment Share on other sites More sharing options...
JF1GG29 Posted May 9, 2018 Share Posted May 9, 2018 I've been trying to get more info on B6 HD ride quality for a year now. Everything I have read points to them being significantly 'stiffer' than the stock Spec.B struts. Link to comment Share on other sites More sharing options...
Zac88 Posted May 9, 2018 Share Posted May 9, 2018 Cant find any information myself besides that B6 are designed for stock springs and B8 are for lowering springs. So I'm assuming the vavlving in B8 are more stiff and is most likely the route I choose to replace my JDM SpecB bilsteins Link to comment Share on other sites More sharing options...
06SubLegTx Posted May 10, 2018 Share Posted May 10, 2018 Hello, Mine is not a racecar like your, But I have B6 on my Legacy and the are not soft in my opinion. My car is not a GT or Spec B. But with Bilsteins warranty and special design tube I could not go wrong. Was your a GT or Spec B from the factory? What Sway Bar and Endlinks are you running? Link to comment Share on other sites More sharing options...
xtea Posted May 10, 2018 Author Share Posted May 10, 2018 Mines not a race are either. It’s just escapism. White line front and rear sways. I think I’m gonna try the b8’s with Swift’s and see what happens. Link to comment Share on other sites More sharing options...
PassedTents Posted May 10, 2018 Share Posted May 10, 2018 Mines not a race are either. It’s just escapism. White line front and rear sways. I think I’m gonna try the b8’s with Swift’s and see what happens. Report back! I'm not 100% satisfied with Koni's + Swifts, so I'd be interested in your experience. Link to comment Share on other sites More sharing options...
xtea Posted May 10, 2018 Author Share Posted May 10, 2018 Report back! I'm not 100% satisfied with Koni's + Swifts, so I'd be interested in your experience. What don’t you like? I just ordered some today. Probably be two weeks before I report back. Link to comment Share on other sites More sharing options...
Cincy05LGT Posted May 11, 2018 Share Posted May 11, 2018 When paired with epic springs, they're too soft for decent autox or track use, while also being too harsh on rough surface streets. I upgraded to KWV2's and never looked back. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted May 11, 2018 Share Posted May 11, 2018 I replaced the factory bilsteins in the rear with b6's and didn't notice much difference. It may have a tad less give than before but it's nothing earth shattering. I'm on factory springs so you may notice a difference being lowered. My car has always been pretty harsh over bumps imo. Link to comment Share on other sites More sharing options...
PassedTents Posted May 11, 2018 Share Posted May 11, 2018 What don’t you like? I just ordered some today. Probably be two weeks before I report back. Main issue is I feel like I'm crashing in to the bump stops all the time. Any sharp transition is a big bang. Ride quality is fine, if a little stiff for Seattle streets occasionally. It might be because the Swifts are such a big drop, there just isn't much travel left in the suspension. Link to comment Share on other sites More sharing options...
utc_pyro Posted May 12, 2018 Share Posted May 12, 2018 Main issue is I feel like I'm crashing in to the bump stops all the time. Any sharp transition is a big bang. Ride quality is fine, if a little stiff for Seattle streets occasionally. It might be because the Swifts are such a big drop, there just isn't much travel left in the suspension. They only have ~100mm of travel in the front, so the Swift’s are putting you pretty close to bump stops statically. You might need to get replacement shorter bump stops or cut your existing one. Link to comment Share on other sites More sharing options...
