08spec.b. Posted May 6, 2018 Share Posted May 6, 2018 Hello, I recently installed a sf air intake on my 08 spec b and I'm trying to tune it for the air intake??? I'm not very good with this AP can anyone help? I might be over analyzing but I cant even move my car cause I dont want to even start it before I tune it... Thank you in advance -Tony Link to comment Share on other sites More sharing options...
Max Capacity Posted May 6, 2018 Share Posted May 6, 2018 Is this an intake that attaches to the turbo or did you just replace the air filter end ? I'm not up on all the names for intakes, IDK what a sf intake is. I do know that you should not replace the stock intake system until your making big HP #'s. Why did you replace the intake ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
thorton0 Posted May 6, 2018 Share Posted May 6, 2018 tuning with the cobb ap is fairly straight forward. follow the screen instructions. there should be a tune already on the ap for the intake stage 1, one for 91 octane and 1 for 93 Link to comment Share on other sites More sharing options...
VespaGTS Posted May 7, 2018 Share Posted May 7, 2018 FWIW - I learned that the Cold Air Intakes are not really a great idea to add simply due to making the engines run lean (this makes them go boom early). Also the stock intake is good up to about 300hp. That being said make sure to go to Surgeline and do a Pro tune on it and you should be okay. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 7, 2018 Share Posted May 7, 2018 Correction, stock intake is good till at least 350WHP. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
08spec.b. Posted May 8, 2018 Author Share Posted May 8, 2018 Hey everybody thank you for the response. So I learned that the cobb AP doesnt support a flash on the MY 08 or 09. Only MY05-07 and judging the fact I am making nowhere near the amount of HP that I would even get any use out of I it i took it off. Thank you again Link to comment Share on other sites More sharing options...
relative4 Posted May 8, 2018 Share Posted May 8, 2018 Hey everybody thank you for the response. So I learned that the cobb AP doesnt support a flash on the MY 08 or 09. Only MY05-07 and judging the fact I am making nowhere near the amount of HP that I would even get any use out of I it i took it off. Thank you again Who told you that? Nevermind, doesn't matter. You need to get on the phone with Cobb, their tech support is very helpful and will clear up your confusion tout suite. Link to comment Share on other sites More sharing options...
WRX USA Posted May 8, 2018 Share Posted May 8, 2018 Hey everybody thank you for the response. So I learned that the cobb AP doesnt support a flash on the MY 08 or 09. Only MY05-07 and judging the fact I am making nowhere near the amount of HP that I would even get any use out of I it i took it off. Thank you again That’s definitely incorrrect, given you have the correct AP. https://www.cobbtuning.com/products/accessport/subaru-accessport-v3-ap3-sub-003 I have an 09 Outback XT that is essentially a SpecB wagon and I have the Cobb SF intake. Surgeline can definitely help you out. They just did my build and tune. Link to comment Share on other sites More sharing options...
08spec.b. Posted May 10, 2018 Author Share Posted May 10, 2018 That’s definitely incorrrect, given you have the correct AP. https://www.cobbtuning.com/products/accessport/subaru-accessport-v3-ap3-sub-003 I have an 09 Outback XT that is essentially a SpecB wagon and I have the Cobb SF intake. Surgeline can definitely help you out. They just did my build and tune. I called surgeline and they said infact the AP doesn't support a flash on the 08... they were shocked as well. I believe I spoke to Brandon? But I can bring it by and they could get me a short term solution until I get it tuned? Do you know how to reflash it on the AP? I've tried and have the same ap you posted a link to.... Link to comment Share on other sites More sharing options...
Max Capacity Posted May 10, 2018 Share Posted May 10, 2018 What Cobb AP do you have, version 2 or 3 ? Both my cars have version 2's. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
08spec.b. Posted May 11, 2018 Author Share Posted May 11, 2018 I have the version 3... should I have gotten the version 2? I plugged in all my cars into onto the cobb website when I purchased and it told me that's the one that's compatible with my 08 Link to comment Share on other sites More sharing options...
Max Capacity Posted May 11, 2018 Share Posted May 11, 2018 I believe V3 is more adjustable...? I leave issues to my Tuner to fix. Someone who is better at playing with these cars can help you. You may want to PM "covertrussian" look for is long post below in this forum. Or check out the sticky's in the top of the Tuning Forum. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
08spec.b. Posted May 14, 2018 Author Share Posted May 14, 2018 Copy that! Thanks max. Link to comment Share on other sites More sharing options...
