JMJ5150 Posted April 9, 2018 Share Posted April 9, 2018 Hello.. I removed the passenger side valve cover but do not remember the locations for the small screws.. Can anyone help? I've been searching for hours .. Link to comment Share on other sites More sharing options...
Infosecdad Posted April 9, 2018 Share Posted April 9, 2018 Sorry, not understanding what you are asking about. Can you describe more or attach a picture? Link to comment Share on other sites More sharing options...
JMJ5150 Posted April 9, 2018 Author Share Posted April 9, 2018 http://legacygt.com/forums/attachment.php?attachmentid=93506&d=1292393772 What location do the smaller screws go? I removed the screws without realizing there are 3 small screws and 5 longer ones.. Link to comment Share on other sites More sharing options...
awfulwaffle Posted April 9, 2018 Share Posted April 9, 2018 Shorter ones front, longer ones middle and back. Link to comment Share on other sites More sharing options...
JMJ5150 Posted April 9, 2018 Author Share Posted April 9, 2018 Shorter ones front, longer ones middle and back. Right on! Thanks for the help.... I guess the fun part now is the driver side... Link to comment Share on other sites More sharing options...
edgemoulic Posted April 9, 2018 Share Posted April 9, 2018 I just did that lately, driver side is a bit tricky but the screws there were all the same compared to the passenger side. I didn’t take off the fuse box I just play a little bit to take it out properly, be careful when putting it back because you might damage the seals if you can’t go trough that tight corners. Link to comment Share on other sites More sharing options...
JMJ5150 Posted April 10, 2018 Author Share Posted April 10, 2018 I just did that lately, driver side is a bit tricky but the screws there were all the same compared to the passenger side. I didn’t take off the fuse box I just play a little bit to take it out properly, be careful when putting it back because you might damage the seals if you can’t go trough that tight corners. Is removing the fuse box easier than lifting the engine? Link to comment Share on other sites More sharing options...
edgemoulic Posted April 11, 2018 Share Posted April 11, 2018 Why lift the engine when you can play it and take off the cover valve. It takes around 20mins. max for a beginner. Link to comment Share on other sites More sharing options...
JMJ5150 Posted April 11, 2018 Author Share Posted April 11, 2018 Why lift the engine when you can play it and take off the cover valve. It takes around 20mins. max for a beginner. Sounds good to me.. the bottom right screw seems to be tighter on the driver side. Your engine is the N/A version and much easier.. The turbo valve cover is a PITA... UPDATE.. I was able to take off all 7 screws out and the last bottom right screw won't come out til I remove the cover.... I can try to wiggle it back in when putting the valve cover back on... we'll see this weekend Link to comment Share on other sites More sharing options...
