pamike Posted February 15, 2018 Share Posted February 15, 2018 I've been searching the various forums and havnt come up with a definitinitive answer. When I do the timing belt job at some point I'll need all the torque specs. So if anyine knows them or has a link to another post with them that would be awsome. Crank pulley, all idler pullies, water pump /tensioner, etc... Only thing I've come up with is water pump possably being 9 ft.lbs and idlers being about 28 ft.lbs but I don't know if that's accurate Link to comment Share on other sites More sharing options...
Gex Posted February 15, 2018 Share Posted February 15, 2018 From the service manual Link to comment Share on other sites More sharing options...
pamike Posted February 16, 2018 Author Share Posted February 16, 2018 Awsome.. Do You know the torque for the crank bolt/pulley and the water pump bolts? Didn't see that mentioned on there Link to comment Share on other sites More sharing options...
DaveWaters Posted February 16, 2018 Share Posted February 16, 2018 Check the vacation pics .. its all there.. tightening the crank bolt is a two step process.. also be careful the smallest idler is less torque..iirc 18lbs or so Link to comment Share on other sites More sharing options...
pamike Posted February 16, 2018 Author Share Posted February 16, 2018 Check the vacation pics .. its all there.. tightening the crank bolt is a two step process.. also be careful the smallest idler is less torque..iirc 18lbs or so What do you mean by "check the vacation pics"? Link to comment Share on other sites More sharing options...
JazzAvi8r Posted February 16, 2018 Share Posted February 16, 2018 here you go. http://people.csail.mit.edu/ilh/vacation/ check out page 1746 / ME(H4DOTC)-39 for the Crank Pulley, and 1781 / ME(H4DOTC)-74 for the water pump Link to comment Share on other sites More sharing options...
pamike Posted February 17, 2018 Author Share Posted February 17, 2018 Found it. Thanks Link to comment Share on other sites More sharing options...
