batchetb Posted January 5, 2018 Share Posted January 5, 2018 Hey all, I have had my 2011 leg premium for about a year now. My co-worker said my brake light on the driver side was out as he left work behind me yesterday. Upon checking all of the lights, I am out a driver side brake light and a driver side front position light (so...time to replace 2 brake lights and 2 front position lights on my car). I was wondering if anyone had some suggestions on going with LED for either / both of these. Is it as easy as plug and play? I know the installation can be kind of a pain in the a$$ for the low beams, has anyone had issues with these replacements? Any pics of your upgrades would be cool too. Thanks, Link to comment Share on other sites More sharing options...
testa422 Posted January 5, 2018 Share Posted January 5, 2018 ive changed literally every single bulb in the car inside and out to led. i highly recommend vleds for all led bulbs...slightly pricier than others but the quality and brightness MORE than makes up for it. the only issue you may run into with leds in your brake lights is it seems the the 10-12 cars like to go into limp mode or have dash lights flashing everywhere if you dont add resistors or buy self regulated bulbs. i have fully internally regulated leds in my brake lights and i have had zero issues going on 3+ years w them Link to comment Share on other sites More sharing options...
batchetb Posted January 5, 2018 Author Share Posted January 5, 2018 ive changed literally every single bulb in the car inside and out to led. i highly recommend vleds for all led bulbs...slightly pricier than others but the quality and brightness MORE than makes up for it. the only issue you may run into with leds in your brake lights is it seems the the 10-12 cars like to go into limp mode or have dash lights flashing everywhere if you dont add resistors or buy self regulated bulbs. i have fully internally regulated leds in my brake lights and i have had zero issues going on 3+ years w them are the vled self regulated? how easy would adding a resistor be? Link to comment Share on other sites More sharing options...
testa422 Posted January 5, 2018 Share Posted January 5, 2018 http://www.vleds.com/shop-bulb-numbers/7443/7443-6-r.html i actually dont have vleds in my brake lights but the link is what id buy from vleds...it says they have a current regulator to prevent issues but not sure if that would cover everything ya know. check your PM's text me or facebook message me easier that way Link to comment Share on other sites More sharing options...
