iiif87 Posted December 15, 2017 Share Posted December 15, 2017 I have recently (2 months ago) changed the oil of my manual 5speed transmission and the rear diff. I went under the recommendation to use Motul 300. I did not have issues with the transmission before, I just changed it for maintenance. The car have 190000Km now. Recently, when the weather started to get a bit colder (not too cold lowest is 2C), I have started to notice the gears shifting is not very smooth, and every time I release the clutch with gear I feel a small kick. Also I feel the first and second gears whine increased. I know that in general subaru manual transmission is harder to shift due to the AWD, but now it is a but harder (specially to downshift). My question, did I use the wrong transmission oil going with the motul 300? or is that normal for this car? and my main concern would that damage the transmission? Link to comment Share on other sites More sharing options...
WahooNo2 Posted December 15, 2017 Share Posted December 15, 2017 I would say its normal, probably is too slick for the syncros. If you switch to redline 75w 90ns it will make it easier to shift. Link to comment Share on other sites More sharing options...
apexi Posted December 15, 2017 Share Posted December 15, 2017 x2 on Red Line 75w-90NS, I love it. Don't know if the fluid is the problem or not, but just wanted to give my .02 on that. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 15, 2017 Share Posted December 15, 2017 I just put 3 quarts of redline and one of motul. It shifts just fine and I drove the car in 25-35F temps. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 15, 2017 Share Posted December 15, 2017 I've been using Motul Gear 300 for a few years now, I think its the best stuff out there. On real cold say's like today, it's currently 3F here, I don't expect much difference. May that first shift may be a bit tough, but in general the stuff is good. I have it in both my 5mt and 6mt and rear diff's. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
iiif87 Posted December 15, 2017 Author Share Posted December 15, 2017 Thanks all for the feedback..I think I will leave it for now, and if I feel like it is getting worse I will do the redline motul cocktail. To be honest today and yesterday the shifting was fine, but at the same time the weather is not as cold.. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 15, 2017 Share Posted December 15, 2017 Today after work, temp was 24F, the first couple of shifts in the parking lot were a little stiff. But by the time I had gone 1/8 mile to the next stop sign it was fine. Oh, the morning shifts were fine at 3F after starting the car at 6:01 AM, loading my stuff in for the trip to VT after work. Then rolling down the driveway at 6:05 out into the street, it shifted fine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Wasted Potential Posted December 15, 2017 Share Posted December 15, 2017 I'm curious "why" people go with different brands of a 75w90 full synthetic other than the generic "different additives" or "people have good recommendations for it"? I usually just use valvoline, but I too have no real reason other than habit.. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 16, 2017 Share Posted December 16, 2017 These have seemed to have issues with most fluids. Once the Extra-S was no longer made. Motul Gear 300 became the standard. I used to use Amsoil Severgear, but after a few bearing issues, its Motul Gear 300 for me. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
1-3-2-4 Posted December 17, 2017 Share Posted December 17, 2017 I’m using motul 300 as well and I have no issues Link to comment Share on other sites More sharing options...
