BLBostonLegacy Posted November 30, 2017 Share Posted November 30, 2017 I have a 2005 2.5i, Auto, My gas mileage this past few weeks has gone from high 20s, 25+ down to 14.7 is where I’m sitting at now. I’ve been using the same gas at the same gas station nothing has been changed there is no drivability issues, plugs wires were done less than a year ago, new air filter, oil change, try throttle body relearn...any ideas?As well as my driving habits and places I drive to are pretty much consistent. No funky smells, no discolored exhaust, no check engine light or pending codes. Link to comment Share on other sites More sharing options...
DugsSin Posted November 30, 2017 Share Posted November 30, 2017 Colder weather has arrived how are you tire pressures ? Winter blend gas would be some of it but that MPG is really low. Link to comment Share on other sites More sharing options...
ammcinnis Posted November 30, 2017 Share Posted November 30, 2017 I can't help, but you might have more luck in the Gen 4 Legacy subforum. I am moving the thread there. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
Wasted Potential Posted November 30, 2017 Share Posted November 30, 2017 Where are you getting your actual MPG reading from? Calculated or off gauge. Link to comment Share on other sites More sharing options...
bergs Posted November 30, 2017 Share Posted November 30, 2017 Things that come to mind are to check are tire pressures, binding or seized brake caliper, e-brake engaged or not fully releasing. Cold weather is moving in but a 10mpg reduction is not normal. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 30, 2017 Share Posted November 30, 2017 I'm guessing dragging brakes... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Marvick08GT Posted December 1, 2017 Share Posted December 1, 2017 If you put it in neutral and coast, you can see if anything is causing an issue. I've seen carrier bearings cause this too. If you can coast and MPH stays about the same (manual) everything should be good. If not, its time to get it up and check each wheel individually. Link to comment Share on other sites More sharing options...
ehsnils Posted December 1, 2017 Share Posted December 1, 2017 If it's a wheel dragging then you should get excessive heat from it. A moderate drive, then stop and feel how warm each wheel hub is, try to slow down using the brakes as little as possible when coming to a stop. Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 1, 2017 Share Posted December 1, 2017 O2 sensor. Can go bad without setting CEL. I would check front O2 and try a known good one to see if it helps. Link to comment Share on other sites More sharing options...
BLBostonLegacy Posted December 3, 2017 Author Share Posted December 3, 2017 Thanks for the input guys. Brakes need some work but nothings dragging. Currently displaying 17.1 after driving all day on the highway. Tires are 6 months new and in great condition, air pressure checks out ok. Link to comment Share on other sites More sharing options...
