Amir Posted November 8, 2017 Share Posted November 8, 2017 (edited) Hi everyone, i have a 2008 subaru legacy 2.0 liter(EJ204) with a 5 speed manual transmission, i don't live in U.S and where i live this model is the only available legacy model, now i found a brand new FA20F with a 6 speed manual , ecu and wiring, i was wondering can this engine and tranny be swapped into my legacy, what will be the issues i should consider? The guy i'm buying the complete set says it came off from a subaru legacy GT. Edited November 8, 2017 by Amir Link to comment Share on other sites More sharing options...
Max Capacity Posted November 8, 2017 Share Posted November 8, 2017 I'm thinking that is going to be a big undertaking. Do you have your own auto repair shop and have a great education in automotive engineering ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Amir Posted November 8, 2017 Author Share Posted November 8, 2017 (edited) No i don't , but i have a some good mechanics, the price for the labour is cheap here, i can buy the set for engine, transmission at a good price. I just want to know can it be done operarionally? Edited November 8, 2017 by Amir Link to comment Share on other sites More sharing options...
Merc6 Posted November 8, 2017 Share Posted November 8, 2017 For the right price, anything can be done. Did you happen to have the rest of the donor car to make wiring or sourcing how a part fits easier? 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Amir Posted November 8, 2017 Author Share Posted November 8, 2017 The person who is selling me the engine is also giving me the transmission, wiring and ecu, i have seen ej20x and ej20y and ej257 be swapped on legacy (2005-2009), but i did not find any one who has putted an FA20F into this car. The alternator, ac compressor and all the engine belongings are on the package i am buying. What do you think? Any other issues you think? Link to comment Share on other sites More sharing options...
relative4 Posted November 8, 2017 Share Posted November 8, 2017 I would start by verifying the physical dimensions. The various platforms built around the EJ engines were compatible re engine mounts, driveshaft length, axle location, shifter linkage, and mostly transmission mounts. I have no idea if the FA platform lines up the same, but if not it could certainly be a showstopper. In my limited conversion experience, all those connection points had to be custom fabricated. Link to comment Share on other sites More sharing options...
sshole Posted November 8, 2017 Share Posted November 8, 2017 Wouldn't it make sense that the FA20* would fit in the same space as the EJ20/EJ25*? The FA20F specifically is a 2015+ WRX engine, right? And the 2015+ STI, which uses the EJ257, uses the same body and chassis that the WRX uses, so it would make sense it would physically fit. Also, https://www.carthrottle.com/post/this-300bhp-wrxengined-brz-is-the-car-we-wish-subaru-would-make/ Link to comment Share on other sites More sharing options...
relative4 Posted November 8, 2017 Share Posted November 8, 2017 If the various and sundry 2015 Impreza variations use both the EJ and FA platforms, then yes, it absolutely makes sense that both drivetrains will fit in the same chassis. However, one must still consider all those connection points. The FA and its gearbox may or may not fit the '08 Legacy's engine mounts, transmission mounts, driveshaft length, driveshaft flange, and shift linkage. Again, I don't know. Just pointing out that the OP will need to find out if he does this swap. Personally, I'd find out for as sure as possible before buying. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 8, 2017 Share Posted November 8, 2017 Just saying sounds like a lots of $$$$'s ... wouldn't it be easier to do what most of us do, get a ej257 short block. oh wait, he has a 08 with a 2.0L so it's not even a USDM GT. Still sounds like more work than its worth. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MilesA Posted November 8, 2017 Share Posted November 8, 2017 This could be one of those gifts that is more expensive than it first appears. Here's just a few things that come to mind. I think the front crossmember that the engine mounts to is different in the later cars. The turbo is under the engine and exhaust is not at all the same. You will need some custom exhaust work. FA engines use direct injection that is a higher pressure fuel system than what you have now. You will need a hood with scoop for the top-mount intercooler. You will need a rear differential that matches the final drive ratio in the new transmission. Wiring seems to be a big challenge and that requires some specialized skill and experience. As the joke goes, you can tell who are the Pioneers, they are the ones with arrows sticking out of the front. Link to comment Share on other sites More sharing options...
relative4 Posted November 8, 2017 Share Posted November 8, 2017 Excellent points all, Miles. Who are the ones with the arrows sticking out of the back? Link to comment Share on other sites More sharing options...
MilesA Posted November 8, 2017 Share Posted November 8, 2017 Who are the ones with the arrows sticking out of the back?Those are the critics, usually. Link to comment Share on other sites More sharing options...
GTEASER Posted November 8, 2017 Share Posted November 8, 2017 (edited) https://en.wikipedia.org/wiki/List_of_Subaru_engines#FA20F Since the FA20F is a direct injection motor, you're going to need the fuel pump and possibly the entire fuel system to make it work. This sounds like a really really bad idea. Edited November 8, 2017 by GTEASER GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Amir Posted November 8, 2017 Author Share Posted November 8, 2017 Well, that is what i needed to know, thanks for the great information, you think it's better if i put an EJ20Y or an EJ20X engine into my car? Would be easier? I have the option of one of these engines i mentioned. And yes my car is a european version of legacy. Link to comment Share on other sites More sharing options...
kaluce Posted November 8, 2017 Share Posted November 8, 2017 It's going to be hard. I originally looked into doing it myself on my OBXT with the EJ25 and I was able to get a full T-boned WRX as a doner car, so virtually none of the interior was usable, but the engine, transmission, and diffs were good. 1. The engine mounting point miiiiight just fit. They're definitely a different PN. if they don't fit, you'll have to fabricate new mounts, or manage to drill and reenforce the stock mount, which wouldn't be super difficult, but would require welding and modifications. 2. The trans mounts will NOT fit, and would require custom fab. The 6mt/CVT is a completely different design. 3. The Exhaust would need to be custom. The FA20F will fit in a LGT engine bay (we are able to put the EZ in the bay, after all), but at minimum you will need to have a custom exhaust made. 4. The intake system would have to be a custom setup too. You could go FMIC to ignore the hood scoop issue, but that would be custom piping. 5. The 6mt on the WRX/LGT is cable actuated, NOT direct like the older 5mts. The 6mts in the newer LGTs are also NOT spec-b parts, and they're not as strong as a STI or SpecB transmission. You won't gain much here except an extra overdrive gear. 6. The gain on this would be only a few ft/lb of torque and hp, the real upgrade would be the fuel economy and a newer engine design. 7. You would likely need a custom ECU to run it, or at minimum some method of mounting the new set of gauges to your old dash. The FA20F is a fully CANBUS design, so the gauge cluster *might* work. That said, if you are able to do it as a swap, document and take pictures of it, because when it's done it will definitely be unique. Link to comment Share on other sites More sharing options...
Amir Posted November 8, 2017 Author Share Posted November 8, 2017 How about swapping my ej204 with a ej20y? What will be needed? Any issues? Link to comment Share on other sites More sharing options...
solliekisli Posted January 23, 2022 Share Posted January 23, 2022 (edited) One of my frequent problems is piston ring lodging. The guys at the service station checked through https://autoleap.com. They said that this trouble can be easily postponed until the subsequent overhaul if you use only the original oil recommended by the manufacturer. And it should be changed not in 15 thousand km, as it is written in the manual, but in 7-8 thousand. Then the increased oil consumption will stop, and the rings will not get stuck. The engine, in this respect, will become more durable and long-lasting. Edited January 25, 2022 by solliekisli Link to comment Share on other sites More sharing options...
NORULZleggy Posted January 24, 2022 Share Posted January 24, 2022 I save you the headache and say do not do this. It will not run right. Just go with the motor you have and be happy unless you have deep pockets. Link to comment Share on other sites More sharing options...
