1-3-2-4 Posted October 28, 2017 Share Posted October 28, 2017 I wonder if I'm the only one that has had this issue but does it seem over time it takes more force to press to unlock or lock the car? What can I do so I don't have to use so much force? It's like just pressing it does not seem to be as good as before but you kind of have to press around on the button. Link to comment Share on other sites More sharing options...
relative4 Posted October 28, 2017 Share Posted October 28, 2017 Have you opened it and cleaned the contacts? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 28, 2017 Author Share Posted October 28, 2017 I have and no change Link to comment Share on other sites More sharing options...
relative4 Posted October 28, 2017 Share Posted October 28, 2017 Replacements are cheap on eBay. Link to comment Share on other sites More sharing options...
Marvick08GT Posted October 29, 2017 Share Posted October 29, 2017 Same issue here, just do finger exercises Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 29, 2017 Author Share Posted October 29, 2017 Now the fob sync dropped and it won't lock or unlock at all.. has anyone else had to deal with this? I might just get two new fobs Link to comment Share on other sites More sharing options...
Infosecdad Posted October 29, 2017 Share Posted October 29, 2017 Sounds like your battery might have died, have you tried replacing it recently? Also, my lock stopped working and when I took it apart I found that the SMB had broken the solder joints and come off the board. I just got a used one off eBay for $10 and it works fine now. What I really want to do is get one of the newer styles and get the flip key case for it. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 29, 2017 Author Share Posted October 29, 2017 Sounds like your battery might have died, have you tried replacing it recently? Also, my lock stopped working and when I took it apart I found that the SMB had broken the solder joints and come off the board. I just got a used one off eBay for $10 and it works fine now. What I really want to do is get one of the newer styles and get the flip key case for it. the battery I changed about a month ago Link to comment Share on other sites More sharing options...
Max Capacity Posted October 29, 2017 Share Posted October 29, 2017 How old was the battery you installed ? If you have another Subaru close to your's I have found you can get interference sometimes. My Spec seems more prone to that then my wagon. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
risdb1 Posted October 30, 2017 Share Posted October 30, 2017 Just upgrade to the 09 key fob with intergrated key. Mines work like a charm. Sent from my Pixel XL using Tapatalk Link to comment Share on other sites More sharing options...
Merc6 Posted October 31, 2017 Share Posted October 31, 2017 Sounds like your battery might have died, have you tried replacing it recently? Also, my lock stopped working and when I took it apart I found that the SMB had broken the solder joints and come off the board. I just got a used one off eBay for $10 and it works fine now. What I really want to do is get one of the newer styles and get the flip key case for it. Got flip keys, permanently disabled the chimes and entering the setup menu has been unsuccessful. I have an aftermarket alarm so it really wasn't a priority to get them working. The all in 1 keys are plentiful but the flip cases are hit or miss lately. I went back to my seller and they don't even show the product anymore. End of the day, the all in 1 is good enough but flip keys are the cool thing to do. The flip key is larger than the GM ones found on the 2011-15ish lineup. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 31, 2017 Author Share Posted October 31, 2017 battery was brand new as in took it out of the package new and checked the voltage I think it was like 3.5 or 3.7V Link to comment Share on other sites More sharing options...
Ironworker613 Posted November 3, 2017 Share Posted November 3, 2017 It sounds like battery to me. That battery could of been new in that package for a long time. Take it out and check the voltage or try another new one. Link to comment Share on other sites More sharing options...
Dishwasher Posted November 3, 2017 Share Posted November 3, 2017 subbed, I have the same issue, just started using my backup fob because my first fob doesn't work in my driveway for some reason. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 4, 2017 Author Share Posted November 4, 2017 It sounds like battery to me. That battery could of been new in that package for a long time. Take it out and check the voltage or try another new one. Like I said before the battery is brand new the voltage is 3.7 Link to comment Share on other sites More sharing options...
Ironworker613 Posted November 4, 2017 Share Posted November 4, 2017 If you've tried a known good battery and the battery contacts inside the fob are clean, then the fob is no good. Unless you're capable of checking solder joints and component level testing on it. Even if, at that point its probably not worth it. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 4, 2017 Author Share Posted November 4, 2017 And it's working again... Link to comment Share on other sites More sharing options...
