06SubLegTx Posted September 21, 2017 Share Posted September 21, 2017 Hello, I have a Legacy and when I release the trunk, I hear only a click (latch did release) the trunk will not raise by itself from the seated position. I have purchased New Subaru Trunk Torsion Bars for it and have put them in. The truck still does NOT come out of the seated position, and the latch has released. Before I started, I took pictures of the torsion bars in my trunk and in a 07 Legacy GT with the trunk to make sure mine were installed correctly. This is the way they are supposed to be installed, and they only go in one way. See the image (attached Image). On my car now the bend is in the same position. My request from fellow Legacy member is to do a quick test and let me and other members find out the truth. 1. When you release your trunk from either the key fob or interior trunk release does in raise the trunk from the seated position? 2. Does raise it? 3. How much does it go up? Thanks for participating in this test. I am also going to contact Subaru to see what they say. Link to comment Share on other sites More sharing options...
JmP6889928 Posted September 21, 2017 Share Posted September 21, 2017 Mine has never opened more than a click and I bought the car new in 2004 Link to comment Share on other sites More sharing options...
apexi Posted September 22, 2017 Share Posted September 22, 2017 That's normal, the trunk is not supposed to pop open. http://legacygt.com/forums/showthread.php/trunk-wont-pop-open-84585.html Link to comment Share on other sites More sharing options...
Dishwasher Posted September 25, 2017 Share Posted September 25, 2017 Mine does not pop open when I hit the trunk release on the FOB or from inside by the footwell. Brought to you by Pfizer Link to comment Share on other sites More sharing options...
BGSEXXE Posted September 28, 2017 Share Posted September 28, 2017 Mines doesn't open at all from inside the car and when I open it off the remote I have to help it open. It doesn't "pop" at all. OEM spoiler Link to comment Share on other sites More sharing options...
grovlet Posted September 29, 2017 Share Posted September 29, 2017 yup - mine has never fully flipped open either - it will of course unlatch when the lever in car is pulled or FOB button is pressed - but must be lifted to fully open manually EDIT: My older 98 LGT also had the same type of operation - so not sure if all Subies are designed that way - but seems to be their design methodology Link to comment Share on other sites More sharing options...
