Front LED turn signal resistor wiring question
So I have not attempted the install, nor looked at the wiring into the headlight yet. From searching on here, I have read that two wires connect each turn signal socket. I already have the LED bulbs and Sylvania resistors.
My question is this, how do I wire the resistor? Do I bridge the hot & ground wires? Do I connect the resistor directly to the + wire twice? May seem like a dumb question, but I really don't know.
When I did the DD turn as tail kit, the resistor was already wired into the harness, so I just plugged it in.
As always, all advice or photos of your wiring is appreciated!
