Blue Waffle Posted September 22, 2017 Share Posted September 22, 2017 Fancy battery terminal. https://www.amazon.com/dp/B004NONEZW/_encoding=UTF8?coliid=I1VLAPUJTBO27X&colid=2KPSMEX6W7VZY Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 22, 2017 Share Posted September 22, 2017 Also, think about doing the big 3. Search for it on youtube. You essentially have a 1000W amp. So, the 'big 3' will help a bit in order to avoid voltage drops. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 22, 2017 Author Share Posted September 22, 2017 Fancy battery terminal. https://www.amazon.com/dp/B004NONEZW/_encoding=UTF8?coliid=I1VLAPUJTBO27X&colid=2KPSMEX6W7VZYThat's really fancy lol good thing for me back when I was going to do a install I brought some marine terminals with 4 gauge copper lugs I can use the lugs for the cable however. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 23, 2017 Author Share Posted September 23, 2017 I'm trying to decide where I want the amp under one of the front seats or mounted on the sub box Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 24, 2017 Share Posted September 24, 2017 I placed my amps in the tray above the spare tire. Class D amps are efficient and should not get too warm. You want to avoid mounting amps on the sub box. Bass vibrations may damage internals. Ask me how I know.... Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 24, 2017 Author Share Posted September 24, 2017 I placed my amps in the tray above the spare tire. Class D amps are efficient and should not get too warm. You want to avoid mounting amps on the sub box. Bass vibrations may damage internals. Ask me how I know.... In the tray with the flap covered? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 25, 2017 Share Posted September 25, 2017 Correct. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 25, 2017 Author Share Posted September 25, 2017 Correct. Wow I guess that's pretty efficient Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 27, 2017 Author Share Posted September 27, 2017 Hey from the head unit to the rear trunk area how long is it? I don't know which length for the interconnects I need to get Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 27, 2017 Share Posted September 27, 2017 Can't remember. never measured it really. Just buy a 200ft+ spool of 14 gauge speaker wires. Can be used for this and future projects. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 27, 2017 Author Share Posted September 27, 2017 I have a 100Ft roll but I was talking about the rca interconnects I assume 17Ft and 20 ft would be enough? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 27, 2017 Share Posted September 27, 2017 maybe. not sure though. Also depends where you will tuck the wires. I went under the center console and rear seats. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 29, 2017 Author Share Posted September 29, 2017 I'm stuck between a 8" and 10" subwoofer right now I'm leaning more towards the 8 Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 29, 2017 Share Posted September 29, 2017 I'd go with a 10 instead. Which ones are you looking at? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 29, 2017 Author Share Posted September 29, 2017 I'd go with a 10 instead. Which ones are you looking at? Kicker CompVR CVR102 Kicker CompVR CVR104 Also the amp I'm going to get now is the Kenwood KAC-7005PS Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 6, 2017 Author Share Posted October 6, 2017 ? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 6, 2017 Share Posted October 6, 2017 What is your question? Â Let me ask you this: what kind of music are you planning to listen to most of the time? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 6, 2017 Author Share Posted October 6, 2017 What is your question? Â Let me ask you this: what kind of music are you planning to listen to most of the time? lol it's all over the place classic rock, classical, pop.. it's not set on one type of music Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 7, 2017 Share Posted October 7, 2017 ok. Do you like it low though? And are you planning to build the subwoofer box yourself? Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 7, 2017 Author Share Posted October 7, 2017 Doesn't have to be crazy low and I'm buying a premade box Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 8, 2017 Author Share Posted October 8, 2017 Ugh this car and the door speakers.. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 9, 2017 Share Posted October 9, 2017 Too bad you have a sedan. This would have been perfect for you. http://legacygt.com/forums/showthread.php/grey-jl-audio-stealthbox-2005-2009-wagon-265607.html Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 9, 2017 Author Share Posted October 9, 2017 I switched to a sedan because I got tired of people always asking me to take things around Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 28, 2017 Author Share Posted October 28, 2017 Do they make a harness kit for the front door tweeters? otherwise I have to cut and solder the wires. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 28, 2017 Share Posted October 28, 2017 no idea. Why do you want that? Are you planning to power the tweeters separately from the front mid speakers? Link to comment Share on other sites More sharing options...
