smithy96 Posted August 13, 2017 Share Posted August 13, 2017 hey i have a 2004 legacy with a bpe classis h6 engine and 6 speed manual tans. just needed to check that i have the 6mt gear box if any one can shed some light. according to wiki they started using them on a 2007 spec b but mine isn't that. is there some where on the gear box that will tell me? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 13, 2017 Share Posted August 13, 2017 If the car is not from the USDM it may have a 6mt on a 3.0L engine. http://opposedforces.com/parts/legacy/en_b13/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Rhitter Posted August 13, 2017 Share Posted August 13, 2017 If you can shift into 6 gears (7 including reverse) then you have the 6mt. My OBXT build Link to comment Share on other sites More sharing options...
Holla Posted August 13, 2017 Share Posted August 13, 2017 Does it have a reverse lock out collar on the shifter? Link to comment Share on other sites More sharing options...
smithy96 Posted August 15, 2017 Author Share Posted August 15, 2017 yea reverse lock out . i just went with buying the 6mt kit hopefully it fits. Link to comment Share on other sites More sharing options...
rougeben83 Posted August 15, 2017 Share Posted August 15, 2017 There's a serial no. label on the left side bellhousing on the front. If all else fails, you can use that to look up your transmission specs. That being said, there's a very high chance your 6spd is just like the Spec. B and STI 6 spd we get in the US. There is a newer 6 spd design that first came out with the BM/BR Legacy and in newer WRX's - it's basically an upgraded 5spd (similar case design and internals). Link to comment Share on other sites More sharing options...
