DementedGT Posted June 30, 2017 Share Posted June 30, 2017 Hello everyone, to start off I have a 2005 GT 5spd all stock besides a spt intake. When im on the highway and i set the cruise control it sets just fine, i can accel up and decel etc but at a steady cruise it surges up and down and eventually it will shut off cruise and flash the cruise light. I have no CEL's and no codes stored that i found. everything else in the car works 100%, any thoughts what to look for?? thanks Link to comment Share on other sites More sharing options...
Max Capacity Posted June 30, 2017 Share Posted June 30, 2017 Have you recently replaced a front hub/bearing assembly ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DementedGT Posted June 30, 2017 Author Share Posted June 30, 2017 Have you recently replaced a front hub/bearing assembly ? Not since i have had it. It did this the day i drove it home so i cant say what the previous owner has done. nothing looked out of place when i did brakes on it and both rotors, and hubs looked good, not brand new either Link to comment Share on other sites More sharing options...
Max Capacity Posted June 30, 2017 Share Posted June 30, 2017 I would see if a repair shop will plug in there tester and tell you which wheel speed sensor is going bad. I replace one last Fall, I did a thread on it. Easy to replace with good penetrating fluid. http://legacygt.com/forums/showthread.php/left-rear-wheel-speed-sensor-r-r-257633.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Infosecdad Posted June 30, 2017 Share Posted June 30, 2017 I had that, turned out to be aftermarket front hubs. Bought NTN hubs from ebay (OEM), cruise control has been solid ever since. http://www.ebay.com/itm/Front-Wheel-Bearing-Hub-Assembly-for-Subaru-Legacy-Outback-2005-Up-OEM/200942016207 Link to comment Share on other sites More sharing options...
Max Capacity Posted June 30, 2017 Share Posted June 30, 2017 I had that, turned out to be aftermarket front hubs. Bought NTN hubs from ebay (OEM), cruise control has been solid ever since. http://www.ebay.com/itm/Front-Wheel-Bearing-Hub-Assembly-for-Subaru-Legacy-Outback-2005-Up-OEM/200942016207 Yea, that's where I was going with my first post. That's well documented. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DementedGT Posted June 30, 2017 Author Share Posted June 30, 2017 sounds like ill look a little harder into the hubs etc. Thanks! Link to comment Share on other sites More sharing options...
Infosecdad Posted June 30, 2017 Share Posted June 30, 2017 Yea, that's where I was going with my first post. That's well documented. I figured you were, just adding fuel to the fire. I found in my paperwork that my fronts had been replaced 3x for each side, so I decided that it was best to go OEM anyway and thankfully it solved the cruise control issue as well. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 30, 2017 Share Posted June 30, 2017 ^ My wagon has OEM in the right front and a new Timken in the left. Moog's in the rears. Had a OEM in the left front but it had play in April so I replaced it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
